Specific Pre-build questions
Started by 22350, June 10, 2008, 10:37:05 PM
22350
Alright, these are my specific questions.  I am going to post them over on the hydroxy boards.  Hopefully someone will be able to give me a few answers.
1.  I understand that there is 71 cells in one of Bob Boyce's generators.  My feeling is that this is because he is using just under two volts per cell.  This why you have to take the voltage to the 130volt rang.  Am I correct in this assumption?
2. Assuming that you go with the 71 cell set up, does the size of the plates have to stay at 6" x 6"? Would it be ok to make them 2" x 12"?  vdubdipr thinks it would be ok, anyone else have an opinion on this?
3. What electrolyte would you use?  I think that it is recommended to use lye.  I don't know if that is correct.
4. In a situation where this is being used in a vehicle, how do you deal with the water sloshing around?  Could you fill the airspace with air filter foam?  What are other people doing?
5.  I can't find anyone who know how much gas Brown's gas that a unit like this produces.  I know that there is a lot of variable, but there must be a rough target.  Most produced, least produced..... you know what I mean.
6. Do you have to build the Bob Boyce tuning circuit yourself, or can you buy one that someone else has produced.
7.  I am still trying to get a baseline for how much Brown's gas it take to run a 4 cycle engine.  I know that Bob's cell is supposed to make a more volatile version of the gas.  Since it looks like I am going to produce this as my working cell, what does it actually take to run an engine?  Let's say that I have a 2 liter engine, how much Bob Boyce Brown's gas is it going to take?  I need to know this, because it will dictate how many of these cells I build for testing.  It would also tell me if I have enough real estate, on my vehicle, to produce enough gas.
8. What is the service life of one of these cell?  How often do they need to be cleaned?  This is assuming I use distilled water and a recommended electrolyte.
9. I heard that there were some other materials, that might be more efficient for the plates.  Anyone know what might be more efficient?  There is a company that touts a coating for the plates, that supposedly increases production.
Thanks for taking the time to read this.  If I can get some answers to these questions, I can start building away.
Paul
22350
did you guys hear an echo in the room?
HeairBear
In my opinion you are asking the wrong questions at this point. My main concern would be total cost. 71 plates will add up and thats without the precision cut case. Don't forget about all the connectors, wiring, hose and other odds and ends you will need to finish the job. Bob sells the PWM on eBay for a couple of hundred bux. You will have to buy a toroid and wind it yourself or pay a bit of cash to have some one do it to your specs. In my experience building it yourself is not just cheaper but better since you know exactly what you want.
OK, now you have spent a bit of your money and you also have spent some hours of your time putting it all together and it's ready to roll for a test. If your extremely lucky or you know exactly how it works, it will work flawlessly on your first try. You will also be the first person ever to accomplish this so, congratulations would be in order. Realistically, you'll be testing for a while.
Now, let's say you have it working and you want to run your car on it. what kind of car do you want to install it in? Any vehicle that is computer controlled will make it real difficult and expensive to complete, none the less more testing to make it work properly. About at this time you realize that the water sloshes around and your getting water leakage to the engine. You are not that far yet, so the point is mute.
Have you seen a working Bob Boyce cell yet? Ever wonder why you haven't?
I don't mean to discourage you from building and testing, I just wonder if you have researched enough and made a plan of some sort. There are a few bumps on this long windy road if you know what I mean. If you think you can get a Boyce cell working then you can do a smaller version for testing and maybe try to run a 5hp motor with it and pray that a backfire wont destroy your cell, even with that fancy bubbler you may have. Hydrogen is more percussive than incendiary. The back pressure can rupture the cell without taking precautions.
Good luck!
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
22350
Quote from: HeairBear on June 11, 2008, 10:32:14 PM
Good luck!
OK, let me see if I can answer some of your points.
I have been posting on Boyce's email list and they seem to have trouble giving specific answers. My goal isn't to become an experimenter.  That is not to say that I will have to figure out a working test cell, but I am certainly not going to build anything until I have a design which will serve my purposes. I figured that the Boyce cell would probably cost about 1000 bucks.  I know the stainless alone was 500.  That being said, if I could pay Bob to personally make a cell, which would do what I needed, I would.
I am, however, starting to have concerns about the Boyce process.
The sloshing around was a big concern and was included in one of my unanswered email posts.
My specific goal is to run a 200cc single cylinder engine, in the neighborhood of 15 hp.  After reading, my feeling is that I will probably need about 15 LPM.  This is my only goal.  I don't want to run cars or anything else.
This is obviously where the problem lies.  The only cell that has claimed these kinds of production rates in a reasonable amount of power are Bob Boyce's cells.
If someone had an alternative cell that could do the job, I would love to look into that.
Thanks for the reply,
Paul
Farlander
If you're using electrolyte your wasting your time.  It's impossible to achieve overunity when you have massive current flow, are consuming electrolyte, and are generating heat.  Stick with adjustable frequency and pulse, and bifilar choke coils that Meyer's used.
Car that runs on water
