Avoiding sticky point by making magnet dissapear.
Started by broli, June 12, 2008, 02:03:25 PM
I have been digging in the magnet motor section. It's amazing what you can find. Lots of inspirefull stuff. Anyways I found the following thread...
http://www.overunity.com/index.php/topic,302.0.html
http://kalininaa.narod.ru
You'll have to go down a bit to see some action. But I don't know what the conclusion of this built was but I'm curious whether it could be improved with the rubber/tin shielding. Technically it should eliminate the shield affecting the motion.
AB Hammer
Well broli
Yes this could very easily be improved, for they have over complicated them. But it is also a project that myself and another person are setting up the groundworks to do, when I am finished with my gravity wheels. So I can't tell you what it is but I will say it is miles ahead of what I have seen you post so far.
Alan
resonanceman
Quote from: AB Hammer on June 15, 2008, 02:58:43 PM
Well broli
If  you are talking about   improving this    motor I agree  .........it may  have lots of potential .
WHat  comes to my mind    is a  video  that  I saw  quite a while back .... I don't  remember  what it was called or  where to find it .... and I don't want to  spend all day looking .    Maybe  someone else  will  remember  where it is .
In  the  video  sommeone   was   expermenting  with  magnets and a bar or  iron .
He  demenstrated that the   when he placed  a magnet  at  one end   of the  iron  bar  the whole  piece of  iron  acted like a magnet .        Then  placing  another  magnet  near the  middle   it canceled  out the  magnetic  effects on the   end  of the bar .
It  seems to me that this  affect  might  be usable  to make   this motor  run WITHOUT  moving  the  shielding .
It  would take  some expermenting  and  the balance  would  be delicate .   .............but   I think  that if a bar  of  iron was used  as shielding  ........and a  LARGE  magnet  placed on it   a  distance  away from the    active magnets in the motor .
The  large   magnet could    magnitize   the  iron bar and actually attract   the  piston  magnet .
Once the  piston  magnet got  close enough to   dominate the magnetic field   the polarity of the iron  bar  would switch ......and  that end of the iron  bar  would in effect   become  just   a core   between   2  like  magnetic  poles .
The  key would  be  to find the  balance  between   all the magnetic  forces .........  saturation   and flipping  would have to  happen  very  close to top dead  center .
As I  see it   it would  take a  very  powerful magnet   on the bar to   hold the  magnetic field  long  enough .
Also  the bar would have to  be  fairly thick .
Another  couple of  changes to  make it more efficient
The  top  magnet   should be replaced with another  piston  and  magnet  setup .
While   it should  work with only  one    set  of  pistons ........the  large magnet on the bar is  idle  much of the time .....  another  set of pistons  operating    90 degreees  behind   the original   set of pistons   would     make  better use  of  the large magnet ........ setting    4  sets   up in a ring might  be  better yet .
A coil  should  be placed on the  iron  bar   in between  the     pistons  and the   large magnet .
It  should  probably be shielded   from the  magnet .
The  inductance of this coil ......I believe it is called  lense  effect should  slow  down the  flipping  of  the  magnetic  field in the iron bar ,,,,,,,,,,,giving   the magnets time to move ............
Any  power tapped  by the  coil is FREE ENERGY
gary
AB Hammer
@resonanceman
I see you are doing your home work. I remember that video and it was only a steel bar, but the effect of dropping the magnet was a cool effect. I have already redesigned the one seen on the sight you posted,  to see if it will have any better effects and it does. But it still don't come close to the design we have planned out. IMHO
Alan
resonanceman
Quote from: AB Hammer on June 15, 2008, 06:51:45 PM
@resonanceman
AB Hammer
Yes   I   have been  doing alot of homework
I remember  when I  saw the video  I thought  it was a cool  trick ..........but  wondered  what it could  be good for .  ....  Now I understand.     :)
What  I like best about  this   idea  is that  it working  revolves  around lense  law .......  with most  OU  devices   people are trying to get  around  lense  law ,....... this  idea isn't practical  without it .
If  we  tried this idea  without the coils    the  magnetic  fields  would  switch  way to fast  and   the pistons  would not  have a chance to  move .
gary
