URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
callanan
Hi All,
Please see my two new videos here:
http://www.youtube.com/m1a9r9s9
I believe I have replicated a setup that does the same thing as s1r9a9m9 shows in his videos. I believe the setup configuration can allow a combustion engine to be run on water only instead of petrol/gas through the same fuel system on the engine.
In my videos, you will see I am now replicating an engine's ignition system using a signal generator switching a transistor driver that pulses an ignition coil at 20 Hz. This is powered seperately by a small 12V battery although the sig gen is powered from mains power.
I am now using a 300W 12-240V DC to AC inverter to charge up a small capacitor that is effectively in parallel with the spark plug via some diodes. The system works very well, as you can see in the video and only uses 2-2.5 amps on the inverter's input.
With this new setup I was again surprised to find that even after running it continuously for 15 minutes, the spark plug is stone cold to the touch. The water explosions are cold and there is no heat that I can feel. I cannot explain this and my assumption that it was hot and warmed up the water was incorrect. It is a cold explosion or the explosion itself cools the plug tremendously through very fast evaporation of the water. So it would seem that because the explosions may actually cool the cylinder, external heating to assist the humidity and moisture content of the air may be required after all for cooler climates. Also, there is no smell whatsoever and only cold moisture around the spark plug.
Please see following a circuit diagram of my latest setup and some pictures.
Regards,
Ossie
xbox hacker
mrock: great diagram! I think you might have nailed S1r setup. Now we just need the right turns for for the coils and such  ;D
Mark69
@ Luc and all,
When u guys get this figured out pretty well, can you make a diagram that is easily understood for those of us that do not have any electrical background?  I mean you will need to spell everything out specifically, for me, at least.  I dont know what the different symbols mean and such.  Keep up the great work!!!
MArk
gotoluc
Hi everyone, this circuit idea came to me :).  I did not test it wet but what do you all think ::)
I have to go out for a few hours but I'll check when I come back.
Luc
vlindos
Quote from: callanan on June 29, 2008, 11:34:02 AM
Hi All,
Regards,
Ossie
On your circuit there is "90V Neon" what is that neon lamp?
