URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
resonanceman
Quote from: Mark69 on June 29, 2008, 11:44:00 AM
@ Luc and all,
When u guys get this figured out pretty well, can you make a diagram that is easily understood for those of us that do not have any electrical background?  I mean you will need to spell everything out specifically, for me, at least.  I dont know what the different symbols mean and such.  Keep up the great work!!!
MArk
Mark
At this  site
http://www.free-energy-info.co.uk/
Chapter  12   is basic  electronics  from  the  viewpoint of   a free energy  expermenter
Once  you  study that chapter you  should  be able to  follow MOST of the  stuff on  this  site .
gary
nightlife
Is it possible that s1r could be using a pump start relay and that is what is in the container?
exxcomm0n
@ Luc
I apologize for my previous post as I did not read enough and it was not relevant to your experiment.
I would like to propose that the next step (after successful replication) be to replicate the effect in a closed atmosphere (with some sort of pressure gauge) to measure the energy produced by the radical disassociation of the water by plasma.
I thinking of a cheap clear plastic soda bottle with the label peeled off, a modified spark plug "screwed" into the side, a pressure gauge in the lid/cap, and a way to introduce water mist into the air tight atmosphere of the bottle.
I will try to replicate your schematic and do this (I will need the help of a ham radio friend to realize the electronics).
A very exciting effect, and I hope to contribute good factual data to your discovery.
:D
When I stop learning, plant me.
I'm already of less use than a tree.
ramset
EXX  A chamber to compare fuel [gasoline]Versus the effect would probably be more productive attaching a plenum to plug base should be relatively easy with a pop cork and air dial [presure]gauge   Chet
Thanks Grandma
sigmaX
Hi Everyone!
Congratulations to everybody that is actively suggesting ideas and replicating! I am reading in awe, how, very probably, history might be changed by all you people!! Please don?t forget to sleep a bit ! Ideas will be clearer!
How about water quality ? What kind of watter supply are you using to spray over the spark ?
Maybe someone can use different types of water and see if any difference in explosion is perceived ?
Like: Distilled water, mineral water, tap water, ocean water (salt), etc.
If I am correct, the best water would probably be the one used for HHO (with some electrolytes) or even distilled water ? (I am thinking long term, motor abuse, in here).
Regards,
SigmaX
p.d. On monday, I will try to replicate this for myself. Everything is closed down here, and I am missing the whole setup (got to buy everything!!)
