URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
UncleFester
Bill needs more energy to run on water. Also, he needs to cut the ground electrode off the plug, this will give him more energy for the same input.
Groundloop
All,
The negative terminal of the car battery is going to the engine block. This is the ground terminal.
If the inverter output is going through a "MOT" and then to minus then my circuits are correct.
No problem for me that "Inventor/ Bill" is using my drawings. All I post on this forum is free for all to use.
Does anybody on this forum have a high voltage o-scope probe? Then we can find out the real spark plug
voltage and design the diode strings according to the voltage. I think the voltage is approx. 20 Kilo Volt.
Then we will only need approx 20 - 8 = 12 in the voltage block string. Maybe some more to be sure.
In the cross talk diode strings will will need just enough diodes to block the cross firing since the
voltage and current always will take the low resistance path through the spark plugs.
I think the easiest way to make the diode strings is by soldering the diodes together and use
"electrician" tape over the solder joints and then an other layer (or several) of heat shrink tubing.
Just a thought.......
I think that using this Plasma ignition enhancer on a petrol (gas) run car will be beneficial for all.
Due to the higher spark energy there will be no misfires in the motor and also maybe gas savings
because of a better internal combustion. Any thoughts on this?
Groundloop.
bwb
My concerns on this is if any additional heat is created and how much from the plasma spark in the cylinder. A hot cylinder could equal burnt exhaust valves and also if the spark plugs heat range will be sufficient to disperse the extra heat if any? I'm very interested in seeing pictures of  Bill's spark plugs when he gets back. I do believe that you should run a water injection system with this and be sure to check your plugs at least within the first 100 miles and regularly after that for a while... The condition of the plugs should show you if they are running hot,cold or normal. If hot a colder heat range plug! Remember this is only a my opinion.I plan on putting one of these on my old 79 Dodge 4X4 318 V8 and see what happens when using it with my hydrogen cell and water injection system. ;D
pese
Groundloop
bwb,
If you are running a 300 Watt inverter and is using, let us say half of that energy, then the total added
energy to you motor will be 150 Watt. This is way too small to make any difference in your motor.
Another issue is the improved combustion with a plasma spark. My best guess is that this will not
impact the motor in a negative way. Only one way to find out, try it on your car. :-)
Then we have the spark plugs. Does anybody know if the Firestorm plugs in on the market?
Groundloop.
