URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
Groundloop
@insane4evr,
Thanks for doing the measurements.
Groundloop.
insane4evr
Quote from: Groundloop on September 21, 2008, 03:41:12 PM
@insane4evr,
Groundloop.
NP.
But maybe I got my RPM wrong for the Ford.  ???
Duration between sparks for a single cylinder when it switched to single is 42.5 millseconds. Please check my calculation for a 4 cyclinder engine.
Groundloop
@insane4evr,
Single cylinder spark duration:
t = 42,5mS = 0,0435S     f = 1 / t so 1 / 0,0435 = 22,99    RPM = f * 60 = 1379,31
Groundloop.
insane4evr
@ Groundloop,
Thanks.
So, does that mean that for a 4-cylinder engine, the RPM of the distributor is the same as the main shaft?
Groundloop
@insane4evr,
I'm more of a electronic guy than a engine mechanic but I assume
that every piston has to be moved to TDC for each revolution on the engine?
But since this is a four stroke engine then only one of the pistons will
be ready to fire for each engine revolution. So we will need a firing sequence
of 1324 or something like that. Then you will get one power stokes for each
revolution and will need one sparks also.
So I guess the distributor is geared down 2:1 from crankshaft.
I'm guessing a lot here, you really must ask someone familiar with car engines. :-)
Groundloop.
