URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
bumfuzzled
Quote from: HHOwanabe on July 09, 2008, 05:33:41 PM
Bumfuzzled,
Thanks for the quick response.  According to the diagram (on pg 6 reply #235) the + wire goes from the strobe to the + side of coil.  In that path, is a conection for another wire (with diodes) that goes to the plug cap.  In the picture, that second wire actually comes from the + side of the coil to the plug cap.  The coil output (large plug wire) also goes to the plug cap.  I used 14g wire for the primary wiring and 10g wire to go from the coil output to the plug.  I use gator clamps at the ends of all wires.  My plug is a Champion CJ8, which the salesman told me was a non-resistor plug.
I agree that the strob simply simulates a cars distributor.  But what I don't understand, is why when I wire up this test as shown in the diagram and pictures (without the strobe though) I get no spark when I tap the + side of the battery with the  wire going to the coils + terminal.  If I remove the wire going from the + coil terminal to the plug, I do get a (normal) spark.  Totaly confused???
Sorry, I didn't build that circuit but you can try reversing the polarity on the coil primary. This is what I had to do to get mine to work with the other circuit. Hook everything back up and just swap the + and - on yer battery and see what happens.
callanan
Hi all,
Does anyone find it interesting and somewhat coincedental that after many of us have advanced the technical understanding of how we can explode water quite simply and apply it to an engine here throughout this particular thread, that SR1 decides, after 3 years, to release detailed information that makes no sense whatsoever of supposedly how he does it, whilst at the same time making his intentions clear that he will be protecting his rights to what he believes he has discovered and invented.
We now find all sorts of threads have popped up because of this that are going in all sorts of directions based on the information he has provided? Very interesting indeed.....
Regards,
Ossie
bumfuzzled
Quote from: callanan on July 09, 2008, 11:50:06 PM
Hi all,
We now find all sorts of threads have popped up because of this that are going in all sorts of direction based on the information he has provided? Very interesting indeed.....
Regards,
Ossie
My thoughts exactly. There are too many things that don't add up between what he says and what the vid shows and what the pic and description of the coil shows. I think you and luc have hit too close to home for him so he's trying to throw a curve ball. If I recall he made several statements how he wasn't in it for the money and he wanted to help poor people yet he keeps everything hidden instead of letting it out so thousands of people can perfect it and get it to these poor people, then all the sudden he's talking about a patent. It sure got quiet in this thread after he came out with the new info.
Have you made any more progress?? Do you think we need a huge plasma arc to make this work?
TheOne
Hi all,
Regards,
Ossie
The thing I found weird about it is the new coil have nothing to do of what S1r described on his setup. Also he talked about inverter on his setup. On his original setup you needed some kind of relay with 2 diodes.
Now you dont any of that just need one special coil.
Hopefully its not disinformation, we will see in his next video on youtube about his coil setup
k4zep
Hi all,
Does anyone find it interesting and somewhat coincidental that after many of us have advanced the technical understanding of how we can explode water quite simply and apply it to an engine here throughout this particular thread, that SR1 decides, after 3 years, to release detailed information that makes no sense whatsoever of supposedly how he does it, whilst at the same time making his intentions clear that he will be protecting his rights to what he believes he has discovered and invented.
Regards,
Ossie
Ossie,
As much as I want to believe, and as much as I have learned from you and my own research, and as much as I am convinced that the process your are developing (that S1R says is not how he did it now!) has promise and that your engine and my engine will "run",........
I will simply say if (baring a Radiant Event from unknown process of huge purportions) a 3 coil transformer hand wound over a nail with nothing but a large limited DC current flowing through 2 of the coils (7 turn and 13 turn)  encasing the 3rd coil (5 turn uninsulated!!!!!)  feeding the HV pulse from the original coil to the plug.......If this can provide a 200X boost in output current through the spark gap, the shifting of timing past TDC and this huge flash,  I'll eat that nail........I have also eaten crow in the past!
Sorry S1R and all concerned, even with expressed sincerity and helpfulness, all have exceeded the limits of my gullibility..BS me once, shame on you, BS me twice, shame on me!...I guess we will have to carry on like ol Frank Sanatra sang ......."I'll do it my way"...............
Ben
