URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
nightlife
DrStiffler,
QuoteBeing able to place a charge in water as the videos you listed show, has "Nothing" to do with the "Energy Capacity" of the water. It is simple to get water to hold a charge, but it does not increase the energy available from it.
That may be true but the pre-energized water may be pre-conditioned for the effect to take place. Based on what Luc's experiment has proven, it must be energized before it can be ignited.
Maybe energizing the water gets the molecules moving and that maybe why it can then and only then be ignited.
This is the only thing I can think of as far as why it has to have a initially power introduced first.
eastcoastwilly
Hi Luc,
Great work from you and great input from others. Further to nightlife's suggestion of energizing water I wonder what effect using freshly Ozonated water would have on the effect. Many people are mis-informed about ozone, it is VERY, reactive to most inorganic materials, however Ozone is one of natures wonders for purging the planet from toxins. I don't know if a cheap (O3) water ozonator would saturate enough O3 into the water to make a difference but It might be interesting :)
Good luck and keep up the great work folks
Will
geovel56
Hi Luc and OTHERS,
I guess no forum is immune to off topic posts.  I was truly hoping things would be different here with better moderating of the posts.  Bottom line:  Although HHO and electrolysis is a great concept, and just one workable solution to eliminating the use of fossil fuels, this thread was supposed to ONLY be for determining/developing/replicating and maybe enhancing the circuit used in S1R's project.
TO EVERYONE:
The action between water vapor and a plasma arc IS NOT instantaneous disassociation of water into its components, hydrolysis of any kind and really NOT the topic of this thread!
It is very similar to Flash Steam, if not flash steam itself!  It is very similar to Lightening and Thunder.  Lightening and Thunder is the discharge of high energy which pushes the air molecules between the water vapor molecules in the atmosphere at supersonic speeds.  Thunder is essentially a sonic boom which we not only hear, but also FEEL its concussion.
This is not a chemical - combustion reaction... it is a physical - concussion reaction with enough concussive force to push a piston down.
Now, can we please get back to developing the best circuit which Luc started, and work together to focus on this ALONE.  There are a million other forums out there for awesome alternative energy systems, but extraneous to this particular thread.
As S1R's videos already showed, he IS running the Briggs & Straton engine on water ALONE.  We just don't know what components are in the silver painted "I Can't Believe It's Not Butter" container, which is what Luc felt he had a handle on, and started this thread.
PLEASE!  Let's work together and help each other moving forward with what Luc started and not deviate from the task at hand... to recreate the circuit in the "mystery container."  The rest of the project is already known.
Respectfully,
Geo
NerzhDishual
Hi witty Guys,
Sounds like this bl' oil barrel price is getting to high. This have a gift for
increasing the creativity and the motivations of some free and sharp minds over here. ;D
Thanks a lot for all your informations and sharing...
@Harti_Berlin:
Thanks for the vid.
Quote from: hartiberlin on June 28, 2008, 11:04:14 AM
How to get the resistor out of the sparkplug:
http://www.youtube.com/watch?v=-J2AHNZUZD0
Can somebody please measure what the Ohm value of this resistor is ?
Is it in the 1 to 10  Ohm range or KOhms ?
In France the internal resistance of the Spark-Plug is 5000 ohms (5K).
I have some old car sparks plugs and also a old small motor SP that shows zero resistance!
According to the fact that the spark plug 'leads' have also some resistance, (officially for avoiding
RF interferences, I guess) .
This should be done to increase the mileage.  Unless it were the contrary. :'(
Best
Nolite mittere margaritas ante porcos.
greendoor
Quote from: epwpixieq-1 on June 28, 2008, 09:09:41 AM
... I have what appears to be a stupid  idea ...What if you spray gasoline, with the same sprayer ...?
This is indeed a stupid idea.
NEVER DO THIS!!!  You can blow up the room and kill yourself very quickly.  Hopefully nobody has tried this - otherwise their silence on the results would be due to their instant demise, or hospitalisation with 3rd degree burns ...
I undestand what you are trying to prove - but be safe, whatever you do.
