URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
Shanti
QuoteThe problem i am having at the moment is the capacitors in my voltage doubler,  the caps blow if the coil isnt allowing it to discharge via the spark/plasma gap.  IF i spray too much water on the plug, it stops the firing and the capacitors blow.  I am in the process of making a way to get 400vdc+ without using capacitors.
Well how exactly looks your circuit. Do you also have the diode array to protect the caps? For actually the additional too much water should actually short the HV and not allow it to climb into himalayan heights???
Well, the simplest way (for a short term solution) would be to add a safety spark gap. This means a spark gap parallel to your plug, but with a wider gap. So if the plug gap does not fire, due to any circumstance, the safety gap will fire and like that, the coil voltage will not be able to rise to very high (destructable) potentials.
But actually I would anyway always protect the cap with an additional device like a varistor or a transil diode...Cheap but effective...
QuoteCheck out this clip we should look into Electric Taser circuit.
in this video clip there's a salt water explosion with Taser.
Well I wouldn't call this an explosion compared to the bangs we've already seen here ;D
Shiver
At the risk of going off topic, would this effect have any application: http://uk.youtube.com/watch?v=_ux8nSWmAz0  I'd like to see some water thrown in there.
k4zep
Quote from: happyvalley808 on July 16, 2008, 01:27:44 AM
Hello ,
I've just received an e-mail from S1R . He said he will make another video of the entire set up together.(working circuit)
HV
Hi Happy V,
Yesterday a friend sent me a 1991 French patent application that if it works explains exactly how the nail in the coil system works. He sent it to me for review, had nothing to do with  S1R's strange coil but IF:
First coil is the magnet field coil, second coil is the modulator, third coil picks up energy.  IF hooked up in a series regenerative system, coils the right size inductive and parasitic capacatance wise, spark generated burst RFaround 21 MHz sinewave, it would add the burst to itself in a regenerative feedback loop.  Would work......S1R is either dumb like a fox, just plain lucky, or wise way beyond how he "talks".....I go for the plain lucky right now.  A pain in the ass to be sure of as a lot of things have to fall into place.......but I'll at least give him the benifit of the doubt......
Ben
plasmastudent77
Hi All
Ninjadaniel - i'd have thought that it shoudl be possible to alter the output of a small motor - auto electricians converted my old English Hillman from +ve to chassis to -ver to chassis. My guess would be the change would be an easy fix, although I havent tried it.
That said - I beleive from reading all these posts it is :
(a) worth finding a design for a design for a stand alone ignition system that is compatible wth small engines that is capable of being driven by small engine magneto
(b)
(a) worth finding a design for a design for a stand alone ignition system that is compatible wth small engines that is capable of being driven by a mains supply ( initially ) then work on the modification to run off 12 volts ( i.e. inverter based ).
Another point - DO NOT OVERLOAD AN INVERTER. DO NOT MESS WITH IT UNLESS YOU REALLY KNOW WHAT YOU ARE DOING!!!!!!!!!!!!!!
If you push things too far, it will all end in tears and quite possibly a fire or injury.
Electrical stuff is not to be toyed with.
Cheers
Steve
ninjadaniel
pretty much all cars have positive HV coil, assuming the engine block is earthed (which it always is),  generators that use a motorbike sized ign coil are also positive HV.
I will just get one of those for the test.  Has anybody tried to make plasma with straight rectified AC?  does it do anything? or is 450v+ required?
