URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
gotoluc
Quote from: k4zep on July 16, 2008, 08:05:39 AM
Hi Happy V,
Yesterday a friend sent me a 1991 French patent application that if it works explains exactly how the nail in the coil system works. He sent it to me for review, had nothing to do with  S1R's strange coil but IF:
First coil is the magnet field coil, second coil is the modulator, third coil picks up energy.  IF hooked up in a series regenerative system, coils the right size inductive and parasitic capacatance wise, spark generated burst RFaround 21 MHz sinewave, it would add the burst to itself in a regenerative feedback loop.  Would work......S1R is either dumb like a fox, just plain lucky, or wise way beyond how he "talks".....I go for the plain lucky right now.  A pain in the ass to be sure of as a lot of things have to fall into place.......but I'll at least give him the benifit of the doubt......
Ben
Hi Ben, a very interesting find I must say :D. Are you considering to replicate this patent or effect?
Luc
k4zep
Quote from: gotoluc on July 16, 2008, 11:01:55 AM
Luc
Hi Luc,
Yes sometime today or tomorrow, sort of busy with family and friends and boat dock work project here at the condo.  Will just try it with a plug and see If I can get extra plasma with the setup..Will also monitor the current in the spark with current pickup coil and display on scope, should be fairly easy to verify, good, bad, ugly.......
With the coil sizes, frequencies look about right, worried about Perm. mag. field intensity but not totally out of the park...........Simply removing the soft iron core or removing the magnetic current should give a straight  spark.  This might be a strange but true type of device..Again, this is a WAG (wild ass guess) type of device and THEORY..IF it works, could sure be used in other ways!!!!!
Has anyone seen this(slightly off topic)!
http://www.youtube.com/watch?v=zlinM1wAI5U
Caught my attention!  Be patient, you have to like LOTS of water!  I can NOT explain it either......
Ben
Lakes
Quote from: k4zep on July 16, 2008, 11:33:39 AM
[Snip!}
Ben
Impossible!! A waterwheel driving a generator which drives a water pump which drives the waterwheel???
Wonder how many watts it takes to operate that pump, quite a few I would think...
This requires its own thread... :)
k4zep
Quote from: Lakes on July 16, 2008, 12:04:35 PM
Moderator,
Maybe we could get the gentleman to join a thread here!
JDHardy54@comcast.net     From Video......
Ben
k4zep
Hi Gang,
Did a very loose test of S1R's coil setup.  Green is 5 turn HV, Large black is 7 turn modulating coil, small red to side is pickup.
NO combinations of wiring on the black and red in the magnetic circuit caused ANY change in a normal spark from 1 Hz to 1KHz spark on the plug.  This is not to say it does not work, I just am unable to see any change in the spark or ANY change on the pickup coil on a scope....NADA.......I know it is not exact, was not looking for a "Kaboooooom", but not even a twitch on scope or in spark.....with high current in secondary coils.
Ben
