0 Members and 62 Guests are viewing this topic.
resonanceman
Quote from: powercat on July 03, 2008, 05:16:29 AM
Hi Luc & @
so if we run the exhaust into the intake as a closed loop on an engine.Then water could ignite at spark plug ,will it reform to water ready to burn again?
Hope so ;)
pc
Powercat
Yup
Sr19  siad   he  ran the exhaust  into  the  fuel tank   to  recondense  it  ....... rather than  a tail pile  coming out of the  fuel tank  he vented   the   filler cap .
If   your  cooling loop  was big enough  pretty much all  the  exhaust  should condense .
I would  love to try   to power  a sterling engine  with   water arcing .
gary
gotoluc
Quote from: xilusma on July 03, 2008, 02:30:27 AM
@Gary and all,
The DC and HV-AC are not directly connected. He just used the HV for the bridge (arcing) before pulsing the DC. Just like Luc circuit (if I may say so) or any other arc welding circuit.
p/s: I think there are similarity if not direct understanding of how the TPU's work.
Hi xilusma, very good observations. I is interesting you are talking of an arc welder because yesterday I was working on some renovation work at my uncles new home and was explaining to him this circuit since he is a real EE and how it is really only a short circuit and that is the first thing he said (this is the principal of a ark welder)
Thanks for posting
Luc
gotoluc
Hi Luc & @
Hope so ;)
pc
Hi powercat, yes it should reform to water. If I remember correctly S1R exhaust was going to a stainless Steel tank where the water would condensate and start the loop again.
Luc
resonanceman
Quote from: nightlife on July 03, 2008, 06:02:00 AM
Actually, I am thinking of the salamander more so then the furnace. I use salamanders in the winter and I have had to take them apart and change the plug. I just happen to have one I can take apart and see what it uses to create the spark. I assumed a coil due to the coil wire. Then again, my assumptions have been way off before and they may be once again.
Nightlife
WHhat   is the sparkplug like om a salamamder ?
a  sparkplug  with a bigger gap might be handy .................longer  spark more plasma ............more plasma more power .
gary
gotoluc
Quote from: Dread on July 03, 2008, 07:13:41 AM
Luc.
Referring to Page 1 and your circuit diagram. (thanks) and S1R's comments. Where should the 2nd booster coil be placed and have you tried it?
Rgds.
Hi Dread, at this time we don't wet see a need for it. It seems the small 1uf or 2uf could be doing the same thing. Just replicate my simple circuit and get familiar with the effect and then try making changes one at a time.
Luc
