geovel56
Hi everyone,
Here is a picture of S1R's coil.  I took the liberty to enhance the picture by placing "readable" text by everything he had in his picture.  Hope this helps!
Geo
AbbaRue
Hi All
One can buy a room humidifier that uses an ultrasonic transducer to transform water into vapor.
The unit I've seen uses about 15 watts to produce as much vapor as 1500 watts would boiling it.
The vapor from one of those could be injected into this unit.
dirt diggler
Quote from: AbbaRue on July 08, 2008, 06:19:19 PM
Hi All
Good idea AbbaRue.
I'm wondering if to make the whole electical part more efficiant, this could be used in place of the light bulb in the circuit. then there is less waste in the system as a whole.
ciao,  Dirt
No, really, I love beating my head against this wall.......
Gearhead
Do you think ionized water would help?  There are ionizers available that will ionize water enough to change the Ph down to 2.5 or up to 11.  The claim is that when water is ionized to high Ph (alkaline) it takes on a hexagonal cluster shape.  I wonder if this is how a Joe cell conditions the water?  At any rate it may be a way to add energy to the water to get more power from an IC engine.
callanan
Hi all,
Just some errata pointed out to me by Ben on the schematic of my last post of the Proof Of Concept setup. The household light globes are mistakenly drawn in series but are actually connected in parallel relative to each other only. Also, the output from the string of diodes in the discharge circuit should be connected to the spark plug's ground base and not it's top pin. Apologies for these mistakes.
Ossie
