gmeast
Quote from: alpeko on February 24, 2009, 03:13:06 PM
Hi gmeast,
Yes, in modern cd ignition system is 1uF capacitor,and 300-500 Volts.But my target is working plasma.
For this I want testing diferent circuits.In this moment I don't know which system is the best.Yours experiences and others who build and test plasma spark is very valuable for me.
Thank you again Greg.
Alpeko
Hi Alpeko,
Higher values for the caps gives a very good plasma spark but very bad spark plug wear.  For the same number of Joules, high voltage and small cap gives a much better plasma spark than lower voltage bigger cap.  That is why I use 1uF - 2uF and 400VDC.  The VexUs circuit has never been put on an electronic ignition system so be careful.  It also has never failed to operate.
Greg
gmeast
progress
Hi all,
Finally got re-focused. Since the route I wanted to take with steam 'ingestion', which really should be steam 'injection', is out of practical range not only for me but most everyone else too, I have opted to just go for ultra-high humidity (as an amplification of the 'drip' system I have now) and not try and keep the steam super hot. In this way I can continue with something similar to what I really want to do and also keep testing the plugs and circuitry. I've been stalled long enough. Time to get movin' again.
Greg
alpeko
Hi Greg,
Yes I know that.Simple circuit is always safe.Like you, I think that injection of cold fog and enough plasma spark is a way to water powered cars ?
Reg.
Alpeko
djzissis
Hello everybody..!!
I have just finished the construction of Greg's oscillator.
I haven't got a transformer like greg's (2x10 to 110) but I plan to use 2 identical transformers connected in series. 12 volts to 220 each,
and the central collector will be the connection between the transformers.
Take a look at the board.:
http://www.flickr.com/photos/zissischiotis/3312023452/sizes/l/
I couldn't find 50Ω resistors so i used 47Ω @ 5W. I think that it is still fine.!
On the right you can see the 12V input leads, and upper you can see the output leads with oscillated 12V.
This weekend I am going at my home-village to make "Unity" turn with water.
I hope I am going to make it.!!
Zissis  ;D
alpeko
Hi djzissis,
Very smart idea.Higher voltage is better.I also want make one osc. with 2x12/230V,because in my country 220 V ~ is mains standard.When testing your plasma spark,please post on this forum experiments result.
This mpg improvements is very important parameter for other members.
Thank you again, and all the best.
Alpeko
