xbox hacker
OK... not to start any heated debate or ruffle and feathers  ;)
The Aquapulser seems to work great... and looks even better then it works.....  ;D
And $350 does not sound to bad....
But.. how does it preform under cylinder pressure?! That is the million dollar question. And i know its still new, but how about some real world data from driving. You can't tell me that they haven't even tried to test it out on a car yet, and got data form the test... that's not how R&D works.
magpie
Quote from: xbox hacker on April 25, 2009, 03:01:58 PM
That IS the million dollar question, keep in mind, that even if it doesn't work 100% under the pressure of the combustion chamber but does produce a stronger effect (in the combustion chamber) than the other circuits and does produce a tiny bit of force in there, we will still be a few steps further ahead and closer to our goal and will know that at least the concept works. It is interesting to note that on the Aquapulser website it says that the RPG4700 is just a proof of concept, if they can get enough money they can get to work on a Radiant Plasma system (or whatever they called it :) ).
Shane Jackson
Quote from: gmeast on April 24, 2009, 07:35:27 PM
Actually there is ONE VexUs circuit out there ... the one I originated.  There are versions (few) of that one.  It required using some sort of pump (oscillator), inverter, DC-DC converter or equiv at the front end to get the charge as they all need.
Thought I'd clear that up.
Greg
Yes I should have said versions.
Shane Jackson
Here is a short video with crappy audio.
http://www.youtube.com/watch?v=Ajsf3ytnNKQ
If you are wondering.... Lysol. I think part of the problem is I did not have the plug grounded very well. All my vice grips are in my spray foam truck.... I may do another video when my new plugs arrive.
gmeast
Here are some pictures of my plugs.
All of my plugs wore very well.  I was especially surprised to see the low wear on the beryllium-copper plugs.  Nice job of replicating to Robin David.
Greg
1st photo: far left is the nickel plug with 750 miles, an unused beryllium-copper, 4 be-cu's with 1,400 VexUs miles of  on them
2nd photo: close-up of the unused beryllium-copper plug and some of the used ones
3rd photo: close-up of the nickel plug
