Water for fuel - diesel
Started by nightlife, June 30, 2008, 01:48:44 AM
nightlife
Hi jeanna, I am glad you are interested in this thread. I have seen many experiments you have preformed on other threads and your input here is much appreciated. Please feel free to post any questions and or suggestions you may feel necessary.
You have a good head on your shoulders and I for one like to hear what you have to say.
argona369
Implosion vs explosion.
I was trying to find a water pump that I read about but the closest I found was
The Humphrey pump (the diagram I believe is missing a one way valve in the
?play pipe?.
http://www.angelfire.com/ak5/energy21/humphreypump.htm
The one I remember was a pumping station in England , built a 100 years
Ago and still working which used vacuum to lift water. Might have been the same or a
Variation of this.
There?s also the 6 cycle diesel.
http://www.autoweek.com/apps/pbcs.dll/article?AID=/20060227/FREE/302270007/1023/THISWEEKSISSUE
http://peswiki.com/index.php/Directory:Crower's_Six-Stroke_Engine
and also , water injection is also used in turbine power plants for increased efficiency
and power,
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=JETPEZ000124000001000096000001&idtype=cvips&gifs=yes
http://energy-tech.com/index.cfm?PageID=108&c2e=236&e2e=0&rs=0&artid=420
I wonder if you injected water into the exhaust before the turbo
And used the increased  pressure developed on the compressor side to
Help run the engine by ?compressed air?. (as a efficiency booster,still running on fuel of course).
Might kill or crack the exhaust side of the turbo though.
(some diesels I believe use a throttle plate to increase temperature and
Reduce ?pumping?, that might need to be removed or opened up some?)
Cliff,
jeanna
Hi all u car people,
user zenarrow has compiled a bunch or very relevant videos. He posted his youtube link in the pyramid thread today.
The one on top seems to be about what I was talking about with implosion.
He says his design is not for diesel, but I bet it could be.
have a look
http://www.youtube.com/user/UnityEnergy
back to the side curtains  ;) ,
jeanna
HaroldCR
Hi
  How about some UNscientific info ???  I live in Costa Rica, and drive an old Diesel Land Cruiser.
  I use WELL filtered used Deep fryer oil, and mix with Diesel and a little Regular gasoline. 70% oil, 30% diesel and a ? cup of gasoline, in 10 gallons of mix.
  Use the glow plugs and cycle them 2 cycles. Engine starts and runs a little rough. I keep the plugs lit up, and within a minute or so, I head out. The engine smokes a lite blue smoke, if I don't keep using the plugs, intermittently. Supposedly, the used oil will end up "coking" or carboning up the rings and injector tips, sooo, When I return home, it's ALL uphill, so the engine is really warmed up, I pop the hood, and gently drizzle plain water into the screen type air filter. The water gets broken up, by passing through the screen, and the vacuum should break it up more.
  I know it's NOT injected mist, but, the engine WILL bog down, if I don't run it at least ? throttle. I do this a couple times, and the black smoke, and blue smoke and white smoke (steam) ?? makes an interesting cloud.  ::) ::)  Right now, I think I have a bad glow plug, because I have developed a miss at start up, and it blows a little blue smoke, probably from the oil-diesel mix. As soon as the temp gets up a hair, the engine smooths out and runs fine.
  NOW, a while back, I was getting into the HHO thing.
  I found that later injection was necessary for the EXplosion, before the IMplosion. I have some good contacts on another unrelated forum, that have tried to offer assistance.
  I was wanting to try to inject the HHO vapor into the diesel engine, same as guys do with gasoline engines. One guy thinks he may have an idea, but, the items he suggests are difficult to obtain down here, because my Spanish is Poor, to say the least. Also, Gringos are rich, so, they double or more the prices.
  IF this info might be of interest, I could copy-paste the thoughts this guy sent.
  He seemed it had a good chance of working, without machining the head.
  Unfortunately, this is ALL well over MY old head, so, I'm just rambling on.  ::) ::) ;D
ramset
Harrold yes post it here Thanks   if its real i can source parts in USA and save you some money  Chet
Thanks Grandma
