S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
mrock
capacitor70
Quote from: mrock on July 17, 2008, 01:30:44 PM
c70, What if.
No, difference, more easy to ground...
same is possible on HV side capacitor can be at upper or lower side no matter...
Its all series combination, anything at any place will do...
vrand
Quote from: capacitor70 on July 17, 2008, 11:27:56 AM
working coil circuit, ferrite core
12:32 transformer ratio
Hi,
Interesting circuit, simple and looks effective. Have you tried powering an engine with it?  Looking forward to seeing your video of it.
Regards,
Michael Randall
forest
Great work capacitor70
I have a question : did you tested this circuit without sensing coil and 1n4148 diode ? Are you able to test if that circuit works when car coil minus is not grounded all the time but only when closing path to ground by TIP transistor powered by some function generator or square generator.
What I mean is : maybe a closed path from LV side to the car coil secondary while 330uF cap is charging and before spark occur has something to do. If you could isolate minus of car coil from ground and let it connect to ground ONLY when transistor fires it would be a wonderful information if plasma spark is generated in that situation.
I'm planning to replicate this experiment as soon as I collect all parts. How many turns have each of coil on torroidal transformer ?
capacitor70
My engine is in open state for replacement of oil seals and piston rings, trials on engine are not taken yet.
It is much better than diodes, on table setup it gives much much better result than diode.
