S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
Park34
imo the lamp is for safety right now, basically once an engine gets running on water alone and idling then we can go into how to eliminate the lamp, or hell maybe just drive with your headlights on :)
Shanti
@Harti:
This coil before the cap version I also already suggested.
But just using a coil would not work. As you need quite a high inductance that the HV gets blocked, but at the same time quite a low inductance to let flow a lot of amps.
But I already mentioned: It should work if you do it like in Tesla's Patent about rectifying with coils. If you magnetize the coil core up to saturation-edge in one direction, then the HV will see a very high inductance (the coil with the core), but the LV side will only see an air core transformer (core already saturated in this direction).
With "usual" core materials the inductance difference between HV and LV will be on the order of several thousand times...
You can do this saturation also just with a permanent magnet. Another version for the saturation of the core would be like s1r's, where you let flow a lot of amps already through the coil, before the firing. This would even have the additional benefit, that the coil would additionally to the HV blocking also generate an inductive kickback during the firing and deliver also some HV! And if you time it correctly (FET Driver) you wouldn't even need the lamp as current limiter like s1r, and so don't waste any energy.
About the lamp for current limiting. I also see it like that. First generate a working model. Then it would be very easy to alter the circuit so that no energy gets wasted. I would suggest using a current limiting coil. But for tryouts keep it as simple as possible, so that as many people can work at it as possible...
Addition: BTW, if anyone would like to try this. It is very important, that the coil core is really exact at the saturation edge, and not below or above for this to work! I think this is also one of the main reasons, why people were not able to replicate s1r's setup...(You can easily find the saturation edge with an oscilloscope)
allcanadian
Many of you will not like what I have to say but I will say it just the same. ;D Many here have criticized and condemned this inventor because you feel he is ignorant to the "facts". But you are not seeing the whole picture, the only one who seems to be may be Bruce_TPU. Many here know there is an electric current, a voltage potential and magnetic field but there is much more you are not seeing as nobody has considered the qualities and properties of the fields present.
I knew S1R had knowledge of the fields present the moment I read this----
Quote"There is also a nail in the middle of it as to create a magnetic field in which the wave is formed,this is the reason for the different number of windings it causes the field to resonate and collapse but not reform to send power in a reverse direction back to the engines main coil"
Let's start by asking these questions---
-What wave is being "formed" in the magnetic field? and how is it formed?
-What causes the field to resonate and collapse but not reform?
-If the second and third coils have a constant DC current flow how can, and to what extent can the first coil interact with these coils?
I will not give you the answers but I will point you in the right direction ;)
I made this post a while back----
QuoteI thought you might find this interesting
The january 2008 copy of Discover magazine "100 top science stories of 2007", # 37--"How killer electrons form in space".
The highlights------
1)Superstrong pulses in earths magnetic field can drive electrons to near light speed.
2)Magnetic storm triggered by a coronal mass ejection, a plasma spitball shot out by the sun.
3)The influx of energetic particles create waves in our planets magnetic field.
4)The ultralow frequency waves made the planets(earth) magnetic field lines oscillate and accelerate electrons travelling along the field lines to extraordinary high speeds.
5)ULF waves are standing waves that stay in their location and vibrate like a string.
forest
Quote from: allcanadian on July 19, 2008, 02:00:08 PM
WOW! We jumped at the end of this investigations. Give me a break I'm not prepared yet. ;-)
My personal thoughts : try to find an answer why Tesla worked so hard to get high frequency currents and why finally he used only alternating form of this high frequnecy currents to develop system of practical lighting ?
I think I found the answer. What about you ?
