S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
bumfuzzled
Quote from: cmichaelcouch on July 08, 2008, 09:57:53 PM
Keep in mind that the HV from the Magneto is going in here somewhere.
Michael Couch
The HV goes in on the bare 14 ga wire.
hydrocontrol
Quote from: xbox hacker on July 08, 2008, 09:31:29 PM
So you think its a scam? LOL personally i wouldn't expect anything different. But tis all ways fun to try!
I did not imply that did I  ;)  I just think something is still left out.  ;D Give it a couple more days and a few more people replicating before we go down that road. ::) I still think the setup that gotoluc, Capacitor70, and ozzie are playing with show more promise then the weak setup I see with this spark which looks like a normal spark. No plasma here that I can see. Still I might have something wrong with my setup so a couple more people need to try.
TheOne
capacitor70
How to trigger plasma without diodes ?
1. Coil Black Wire carries high current, red wire low current for bulb
2. Bulb helps to conduct transformer. Without Bulb How you can make transformer work ?
3. Why we are using diodes, diodes prevent HV from going to battery side, we need spark
   at the tip of the spark plug and at the same time DC voltage across the tip. This is achived here with coil.
4. When HV gives spike to the coil, on coil secondery battery is connected which comes
   in series with HV induced in its coil, so the votage at the tip of spark plug is
   Bat + HV, creates plasma channel. No need of inverter, once plasma channel is created and discharge starts you need to disconnect battery
   from draining it completely. Sr1 is taking about some waveforms....
5. Once the plasma channel is created Battery current flows through plasma channel (Thousands of Amps ) and
   bulb turns off, and HV coil is also in off state. This battery voltage is having large current, current is important
   for plasma blast this way it works. Plasma have infinity conductivity (zero resistance).
6. It dosent matter how much voltage is why we need voltage is to just to cover voltage drop of our diodes.
   I have taken trials with 175V DC and 315V DC both have nearly same effect.
Hear is pic of coil wiring... Make sure coil polarity (direction of turns)
bumfuzzled
Cap70, in the photo he doesn't have the high curent coil tied in with the HV out to the plug. Also, look at the main windings, doesn't that look like black insulated wire instead of the bare 14 ga wire he is saying it should be??
