S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
xbox hacker
This is what S1r forgot.....
QuoteYes and I went back and added it to the page. It was about haveing
the # 2 and three coils charged at all times. I set the page up as a
html because my pc for some reason dont make pdf files.
But yes I did go back and put in what I forgot.
I am very tired, sorry.
S1R.
bumfuzzled
Quote from: xbox hacker on July 09, 2008, 05:04:21 PM
He must have forgotten that early yesterday because that's how I hooked mine up. That's what the 60 watt bulb is for, to keep it from being a dead short on those two windings. Main problem is he doesn't say which way to wind each coil, but I still don't see just this coil doing anything.
dani1
ok, lets carry it together:
--- In WaterFuel1978@yahoogroups.com, "s1r9a9m9" <s1r9a9m9@...> wrote:
> The coil must have a power supply at all times to energize the wire
> when the engine coil fires. This can be done by useing a fog light
> or small 12 volt motor, or just some thing that will draw power
> through the wire through the coil. It may be possible to run the
> charging wire from the alternator to the battery through the coil
and
> get the same results. It would not be drawing any power from the
> system because it would not be interupted as it flows to the
battery.
> I am still reading through about 6 thousnd pages of work others
have
> provided on this project. I gots a head ache.
> I am still looking for a source for the relays. If I find any I
will
> let every one know where I got them.
> Some one said that you cant get high voltage from a 12 volt system
> just useing the power of the battery and alt.,. but what is the
> voltage coming from the cars coil to the plugs on a car? the fire
> that has always bit me has been over 28000v @ 0.78 amps. or more.
> now all we are doing is adding another coil to boost the fire from
> the first coil to 100 times the stock out put, but we are doing a
> little more we are slowing it down a little and adding some amps
back
> to it as well.
> It ant rocket science but its not far from it. It seems simple to
be
> able to work, but a lot of time has went into this, and its not
> finished yet.
> The engine still surges. It needs a fuel supply system that feeds
it
> as it needs it. there are other things that need to be done as
well.
> I dont have all the answers but I am looking.
> I just got lucky on the Elcamino and the generator. Now it needs to
> be made to go on any car or truck. and cheap as posible.
> A 65amp alternator will charge three car batteries under a 30
percent
> load, and maintain the batteries at 90 percent charge. So how many
> math-tithions will say this cant be done. When the car is running
how
> much powere does it use? Now starting it is another thing , about
150
> amps is pulled from the battery when starting a car engine it is
> replaced with in the first 2 minutes of run time. this is the
hardest
> time for the batterys life , heavy discharge then quick recharge.
But
> how much power does the rest of the car use? Less than 8 percent of
> the batteries copasity. unless you turn on every thing then you are
> useing 20 percent. Stuff on a car does not draw a constant load. It
> veries with engine speed battery condition and other factors as
well.
> Refrence to GM spects on automoitive electrical system uses and
> condition of components. Thats some tough reading.
> So we put this coil on each plug with a load pulled through it
going
> to maybe some thing that is being used all the time any ways and we
> now have a system within a system that will draw 3 percent more
from
> the power system than before. We are still not over taxing our
> battery and charging system.
> Now as for how to get the water fuel into the cylinders, I havent a
> clue as to how each vehicle will be done. Its not a constant flow
to
> each piston. It takes a lot, but only when it needs it.
> Well as I said I dont have all the answers but I do have a bunch of
> papers to go through and sort out a few more things.
> I am working on a video to show how to make the coil and what it
does
> hooked up and working.
> S1R.
Re: B&S 18 HP Jet size
It didnt matter about the jet size this time , because I ran the hose
into the breather port hole and not through the carb.
None of the engine was modified except the breather filter removed.
This is a stock engine running on water.
The vaccum in the bottle was needed for this test, it had to draw
only what it needed as it needed it , as you could see in video 2
when I gave it to much it shut down and water vapor came out the
exhaust. A valve would have helped but my budget is gone, And its
shoe string streching time for parts.
It has been said that before the breather filter is the best place for
it because of flash back from the engine. It does help to have the
filter between the intake and the gas flow. If you can make a filter
that fits the end of your flow line then you can put it on the rubber
part close to the engine intake. A vaccuum line will draw the gas but
will also draw some of the water from your tank. If its a small hose
you could use a regular gas filter in the line to stop flash back, one
of those clear ones at the parts store.
A Big Thank You S1!!!!
ramset
S1 you post a build vid of that coil  I guarantee you will be compensated Chet
Thanks Grandma
xbox hacker
Quote from: ramset on July 09, 2008, 05:49:39 PM
A video is worth about 10,000 words ...LOL
QuoteThe vaccum in the bottle was needed for this test, it had to draw
WTF... i went to hardware store and spent $1 to make coil....he didnt need inverter....ok, motor = not cheap...BUT STILLL!!!
OK....i got around to making my coil....And it does the same thing that everyone else coil do...NADA
