Has Anyone Demonstrated the Capture and Return of Counter EMF
Started by rukiddingme, July 08, 2008, 10:07:26 PM
rukiddingme
I've seen a lot about EMF, capacitors, back to a battery, across the shaft, etc; but I'm not sure I have actually seen proof of returning EMF back to a system. Is this something that is accepted in general science as true, or is it still speculation?
z.monkey
Are you kidding me?
Howdy,
You are using back EMF every time you crank up you car and go cruising.  The ignition system of you internal combustion engine powered automobile uses a capacitor discharge ignition system.  This ignition system utilizes a flyback transformer.  Basically the capacitor discharges into a coil, the ignition coil.  Modern cars have a coil for each spark plug.  The capacitor discharges into the coil then the coil builds a large magnetic flux field.  When the current from the capacitor ceases there is a cascade effect as the magnetic field in the coil collapses.  This energy is discharged through the spark plug to ground.  The voltage going into the coil is generally around 13.8 volts.  The voltage coming out of the coil is somewhere between 14,000 and 40,000 volts depending on how cool your car is.  This flyback effect is back EMF.
The same effect is happening in your television and your computer monitor.  Both these devices utilize a flyback transformer to generate the high voltage needed to generate the electron beam which excites the phosphors on the face of you cathode ray tubes.
So, yeah, totally proven...
Blessed Be Brother...
Goodwill to All, for All is One!
rukiddingme
Quote from: z.monkey on July 08, 2008, 10:54:19 PM
Cool,
Does that mean in the Kore system, when the current is cut to the pulse coils, the output of the coils at that point can be sent to capacitors to be reintroduced on the next pulse to the coil? If so, how do you contend with the difference in voltage?
Has anyone actually captured the output of a pulse coil, sent it to capacitors and used it to boost the next pulse?
nul-points
hi guys
yes, not on the same scale as Z was mentioning with TVs or autos, but in my switched cap test circuit i capture the back EMF after the switching cap is charged thro' a coil - the 'flyback diode allows the collapsing field energy to dump its energy back into the switching cap & parallel load
in one version of the test setup there is a second cap being charged before final discharge - this cap also receives the captured back-EMF to boost the energy being stored
with a high-impedance load the flyback voltage will appear as a high voltage-spike across the load - high volts, low current - with a low-impedance load (or big capacitor), you'll more likely see a low-voltage peak at that point - low volts, higher current (same energy)
if i use a small DC motor (salvaged from a PC CD tray drive) as the load you can hear the motor speed up & down as the flyback diode is connected in & out of the circuit
to check that there is a real contribution of energy going thro' the flyback diode i also tried replacing the diode with a variety of different coloured LEDs - the LED lights brightly, showing that there is a significant amount of energy being returned to the cap or load thro this path (but an LED is not as efficient as using a diode - choose lowest forward Vdrop diode for required Amperage)
since the diode/LED is reverse biased to the normal circuit voltages the only way it can be passing current is in the flyback mode
hope this is some help & encouragement - keep up the good work, guys!
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
resonanceman
Quote from: nul-points on July 09, 2008, 03:10:28 AM
hi guys
sandy
Nullpoints
It looks to me like you have  made  a Tesla  switch
gary
