dlwammo
@ResinRat2
What I've done in the past to seal thermocouple leads into a small acrylic container of water was to use a piece of rubber or flexible tubing that is a tight fit for the thermocouple (or in your case the electrode) and then using adhesive to seal the tubing in place once it's been fed through a hole in the acrylic case.  This should allow the electrode to grow and shrink while maintaining a tight seal.
EDIT: (added)
Another way is to use two (2) o-rings.  On each side of the acrylic.  Use something like marine Goop to seal o-rings to the cover. Don't use it to seal the electrode.  The o-ring will take care of this.  I use this double o-ring as well when I can't find the right size tubing to work.
Hope this helps....
Dan
Don't mess with old farts... age and treachery will always overcome youth and skill!
rwwendland
Perhaps you could try using a 'compression' type cable gland. If you look at www.rswww.com and do a search for GLAND I'm sure you will find something very suitable. Keep up the good work.
ResinRat2
Thanks for the suggestions Dan and RW. These look good!
ResinRat2
Cheap fuel cell?
http://www.youtube.com/watch?v=-cQg0Ur9Cko&NR=1
Thoughts anyone? This could be a possibility. Safer than plain platinum.
bluebatch
Thanks for your responses to my posting about your 5-metal cell on YouTube. I'm thrilled that you are doing this work, and sharing it so well. I know, it's Linnard's patent, but you are doing a lot to make it accessible to the public, to make it undeniable.
I'm working on a high-output elctrolyser unit a la Joe Cell or Meyer cell.
This open-source collaboration is terrific, a new paradigm for a restorative, cooperative, (post)industrial society
