New Newman Motor Replication
Started by Careica, July 22, 2008, 02:38:10 AM
seekingknowledge
Quote from: khabe on July 30, 2008, 03:02:19 PM
Hmmm ??? It comes more and more interesting,
Regardless - why at all this motor? Why not just carbon brushes, bit copper and spark? When we dont need to spin this stupid monster then we will have much more free energy  :o
Otherwise asked - any proof that copper/carbon/spark makes energy?
If yes than this Motor is just the concealment of real PowerHouse ...and it is masterfully conspired ,
Now I can understand why Maestro kept at a distance to motor building , was concentrated to commutator ...
khabe
Because khabe if we are not gunna have the motor we still need the coil so that we connect the battery to create the magnetic feild then we disconnect the battery and the magnetic feild collapses and it pushes the electrons in the opposite direction and jumps across the contact point and makes a spark,
so sparking happens on disconnection not connection of the battery, now according to stefan and i beleive that you charge the battery from the coil alone without the magnet (you would need something to drive the swith open and close) you could even maybe have an iron core to help make the feild a bit stronger along with a bigger feild collapse and more power output (backspikes)  but not as much power output (overall backspike plus mechanical power) as having a magnet in the middle, because you then
have what power you get from the electromagnetic feild interacting with the feild from the permenant magnet which is free.
So the answer to that is you need a coil and yes you can do it with or without a magnet, but without the magnet you forfit the mechanical power and if you use a magnet you open and close your contact materials instead of having to use another electric motor or something.
Newman machines dont have iron in them by the way as it hinders the performance, but if you were just using a coil i suppose you may aswell have an iron core.
khabe
No way to talk round me,
Hundred differend brands of brushed motors - nobody has detected carbon/collector "fusion" effect - the only thing - just only losses + wear and tear,
Have seen arc-light copper melting furnace - huge carbon electrodes, copper, vacuum or without, nobel gases or without ... inductors, transformers ... what ever!
But only horrible noise - colossal amperage - huge costs - nowhere helpful fusion, http://en.wikipedia.org/wiki/Electric_arc_furnace
This is BLUFF!
khabe
PS:
We can read that JN?s Books are available, as well as in pdf format ... costs money - $400 - of course - but free energy guys are really free-men - offered cracked version - all must to be FREE ;)
Even intellectual properties of Maestro  :o
And:
Fusion of carbon takes place in high mass stars where core temperatures exceed 600 million degrees K. Carbon may fuse with itself or with other preexisting nuclei in a series of reactions leading to the build-up of heavier and heavier elements  >:(
onlov
Quote from: khabe on August 01, 2008, 07:57:53 AM
This is BLUFF!
khabe
Early street lamps has plasma spark cap between graphite rods. Maybe these devices are produced lots of free energy!  But at that time Stefan was not be born. So he has not opportunity to measure free energy from these lamps ;D
Synonyms for Overunity = sparks, lihtnings, smokes, magic, snake oil... ;)
Careica
Quote from: onlov on August 01, 2008, 08:29:16 AM
Did you just undersand what you said? Light bulbs are basicly inside of airtight glass container, or however you call it. Electrons cant fly there, because it is airtight.
+ There is no coil
+ There is no back spices
onlov
Careica:
QuoteDid you just undersand what you said? Light bulbs are basicly inside of airtight glass container, or however you call it. Electrons cant fly there, because it is airtight.
Don't embarrass yourself. You have any kind of knowledge of these lamps...
