New Newman Motor Replication
Started by Careica, July 22, 2008, 02:38:10 AM
khabe
I meant why not Newman motor drives your lawnmower (NewmanM instead Gas engine) - at the same time (wire out) makes hydrogen and charges batteries for your house  :o
Im ready to eat my pants if you are able to drive your wind-generator with Newman Motor - I mean successfully drive when heavy loaded, not stupid show off with LEDs.
About your hydrogen videos - oh dear! - I did not know you have so feeble sense of humour. At that experiments with +/- in water we did carry out somewhere in grade school - 40 years ago ...
You are speaking something about spark ... sorry -I did not see it ... but ok, it does not matter.
Let it be,
Dont worry,
Have a nice time,
khabe
Careica
Quote from: khabe on August 06, 2008, 03:20:48 AM
Let it be,
Dont worry,
Have a nice time,
khabe
Onlov should realy build his own replication, because it don't cost much of money and it is easy to build.
Khabe, what you meaned whit wind generator?
          I think to put load on my motor. I will find diffrent weight flywheels for my motor.
onlov
Vinyasi
Using the Joseph Newman motor as a starting point, I simulated his motor as an overly simplified LTSpice model in two modes: full throttle speed supplying 200 amps and cruising speed supplying 50 amps to this two coil simulation. The improved range per recharge of the battery pack is a gain from a 60 mile range to a range of several thousands of miles. Viewer be wary of taking these simulations literally. Also, the neon bulb might best be actualized by the use of a suitable spark gap to handle the high voltages, etc?
JPG screenshots of simulation...
https://is.gd/evfullthrottle
https://is.gd/evcruisingspeed
LTSpice asc files...
https://is.gd/evfullthrottleasc
https://is.gd/evcruisingspeedasc
References...
http://is.gd/fullthrottlecurrent
http://is.gd/evcruisingamps
http://is.gd/newmanchap6
BTW, the National Bureau of Standards admits in their report to shorting out the Newman coil by connecting a resistive load in parallel to the Newman coil of lower resistance than the Newman coil. Thus, a current division circuit was established in which a greater percentage of current would want to travel the Bureau's test load's path of least resistance rather than travel the path of greater resistance through the Newman coil and, thus, invalidate the test as being a non-exclusive test of the Newman device.
http://files.ncas.org/nbsreport/introduction.html
