Thanks to ALL for your help!!
I found a flaw in modern physics
Started by atomicX, July 22, 2008, 06:31:38 AM
therealrasta
Hell yeah.. Tell us.. And if your wrong someone will just let you know.. But if your right..   ;D
atomicX
You know what guys, the world is already messed up as it is today.  Let's have fun today.  Off we go...
I believe that we are right.  There exist extra energy added to unity.  In this argument, I will pick Isaac Newton and his work .  I will not express my idea as other scientist and believers by experimenting but rather through the scientific reasoning.   Physics has stumbled hard on explainations that it divided into branches now such as classical, quantum, relativity, high particles.. etc...  I believe that all of them are wrong because they based on the mathematical framework that is not perfect.  I'm calling out Calculus is the root cause in this .  Let's take us a little bit back to the old days when Calculus was born.  It actually not excepted by the mathematicians back then because it did not satisfy Archemedian properties.  Archemedian properties believe in infinitely small (0) or infinitely large (infinity) and not "infitestimal small" like Calculus.  Be aware that though infinitely small  is almost the same as infitestimal small, they are NOT the same.  Let's consider a case where Calculus failed us in identify free energy.
Assume we have an object mass m attach with a fine string with constant circular motion about its center.  Let's consider the forces consider by Calculus, namely the Centrifugal/Centripetal force pair.  Calculus describe the force as dv/dt .  The direction is pointed directly to the center.  If one looks closely at the derivation of how dv/dt work.  The direction is a resulting vector of 2 velocity vectors that when they ultimately come together, will point directly at the center.  The term "as t approach zero", direction of acceleration APPROACH  perfectly inward.  Note that the term approach implies "infitestimal", thus it will never be perfectly inward... but off center!  Therefor, a none zero tangent acceleration (call Z acceleration) exist as a component of this off center acceleration!  One may argue that we do have to freeze the picture to actually calculate the point like, I argue that freezing the picture implies t=0 .  t=0 is a fictitious state for mathematic and will have no sense in reality because time will never be zero in reality.  In term, my arguement is even a bit stronger than Mr. Newton.
All this concluded to the existance of Z acceleration tangent to the circle with constant velocity.   Its magnitude is proportional to centrifugal accleration, hence a =kZ where k is a constant (sin.beta to be exact) .  If centrifugal acceleration is proportional to the mass and radius of the system, then Z is stronger as the intertia of the system increase.  The extra energy one get per circle is proportional to  Z times the circumference (if ball system) .   If the resistance (I call interference due to many type of resistance) is greater than the extra energy per cycle (power), then the system will stall .  If less than, the system is overunity.
I'll verify these effect by case induction.  Big generator  self substain due to high Z .  Magnetic motor self substain at high speed due to high Z at high speed and over come interference.   This will implies on all rotating object.  They will generate extra energy.  In theory, if you equip your car with higher inertia wheels, you will save gas!
Hope you guys have fun and enjoy this post.
