And do you still not understand?
Started by Alexioco, August 01, 2008, 12:47:26 PM
Alexioco
Quote from: AB Hammer on August 01, 2008, 09:29:44 PM
Greetings Alex
I have done just what you are purposing. It has a jerking effect and will spin if you spin it, for a few turns and will settle with the weight on the down side. The weight settles below the 3 to 9 mark and finds equilibrium.
Hey Alan, if you can make it so it does not pull on the strings on the left, then it should spin, yes?
p.s When are you showing us your mechanism? I would very much like to study it...
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
AB Hammer
Alex
That is what make the jerking action, and each jerk causes the loss of the possible movement with a negative tug.
Alan
Alexioco
Ok, I think I have got something good here...
Based on the same principle, except that the weights dont pull the strings on the left hand side, only the right which may cause some kind of motion...
Here we go...
When a weight falls out it pulls on some chord pulling that side of the wheel down, when a weight falls in, the tension on the chord is released as the weight rests on the axle...
