Fueless Friction Heater Manufacturer Found
Started by Cap-Z-ro, August 01, 2008, 02:59:08 PM
resonanceman
Quote from: Cap-Z-ro on October 12, 2008, 11:32:07 AM
The motor is 230/115 volts - 6.5 amp AC Gary.
I would need some type of automatic programmable dimmer device...if there is such a thing.
Regards..
Capt Z
Unfortunantly  they are not cheap  and you said on   reply  49 that they are hazardous.
Most  dimmer  switches   that I have seen  are 600 W
If your  motor is   115V  at 6.5 A  that is  747.5 W   there may be a  simple  dimmer switch  out there that can  handle  the  load .
It would  not  be  programable  .  but it might  get the job done.
gary
Mark69
Hey,  how about wiring up a programmable house thermostat to it?  You can use the fan speeds low, medium, high and program that to start slow and work to fast?
Mark
noonespecial
I still don't understand the purpose of this heater? How is it any more efficient than a standard electric baseboard heater?
Cap-Z-ro
I don't have the operational knowledge of how compatible a programmable thermostat would be witha single phase ac motor Mark.
Thanks for the suggestion...at least I can ask somebody if it would do the job.
Noone...read the links at the start of the thread...the diagram is pretty self explanatory.
Regards...
noonespecial
Hi Cap-Z-ro,
Where are the diagrams? I went to the link and all I saw were a bunch of pictures.
Bottom line for me is that there is no way you are going to heat your 'average size house' for $5- $10 a month with this device.
Is there any test data to show that this is true?
