Capacitor bank
Started by guruji, August 05, 2008, 03:24:15 PM
guruji
Hi guys how can one do a capacitor bank?One should use same  voltage and uf caps?
Can one use them hooked to a 240v inverter to help motor surge so helping inverter watts?
Thanks
gyulasun
Have a look at pages 7-11 of this PDF file: http://www.panaceauniversity.org/RV.pdf
Use at least 400V AC rated RUN type capacitors.
To make sure you switch on just enough capacitor, you wish to use a Kill-a-Watt meter to see the PF (Power Factor) values directly.
pese
Quote from: guruji on August 05, 2008, 03:24:15 PM
Thanks
use an lamp bulb (also halogentube) to protect the inverter from surge current.
the lam in serie to the load.
this will light first , after the go dark, you can close the lamp with an swicht (to electrical short) the lamp.
if you have 200 watt motor an 100 (150watts) lamp will be enought)
G.P
wattsup
@guruji
See this post made some time last year. Also check the thread.
http://www.overunity.com/index.php/topic,2551.msg36033.html#msg36033
