OVERUNITY.COM LOGO CONTEST!
Started by winner, August 06, 2008, 03:35:42 PM
Bruce_TPU
This need a bit of refinement by someone who can use 3d graphics, like Tao, but it gives a general idea, of my idea.  :)
Cheers,
Bruce
Freezer
Was thinking you could have a animated spinning wheel for the O, but don't know if that will tax your bandwidth too much.  I think maybe someone should list some requirements as to sizes and where its going.
4Tesla
winner
Quote from: Freezer on August 08, 2008, 12:00:02 AM
...I think maybe someone should list some requirements as to sizes and where its going.
OK, here's a little more guidance with respect to the banner. The existing banner here is 151 pixels high (the space below H, R at top right and above the horizontal menu). For the web version of the *logo*, I recommend keeping in this ballpark for height, give or take, and a similar width as well. We need to be clear on the difference between logo and banner.
I could go into a lot more about this, but for now let's keep the above in mind and imagine a logo fitting in a similar height header.
For larger web presentations or posters the basic web logo could be embellished with more elements like lightning, finer details, etc. but we should have something that is visually clear in the 150-or-so pixel dimension for the header.
Graphics software (try IrfanView!) is great at dimensioning images. If you are starting out with something large, detailed, and spectactular, try scaling your image down to a 150 or so pixel height and see then what it looks like!  ;D
I'm not sure how Stefan feels about replacing the entire banner image (I think this glassy look is kinda cool myself), so for something on that scale we'll have to see what he says. I'm pretty sure he'd say "go for it," and I'd like to see some creative banners as well, so I don't see any harm in coming up with banner designs as well.
Hope this helps!
Cure diseases with grid computing power! Join World Community Grid!
Click logo for worldcommunitygrid.org
Paul-R
I would suggest a picture of a 1 litre car towing two caravans which contain two
suitcases of useful papers and 2 tons of brick rubble.
