A Pollution Free Energy System
Started by FreeEnergy, October 16, 2005, 05:01:36 AM
FreeEnergy
also found on the web....
"The speed is controlled by the use of P.M. magnets in one field and D.C. magnets in the other. In figure 1 (the magnetic fields), an opposing force is created. This force is applied to the Wheel assembly, (in figure 2.) with the use of two shafts, (one inside the other), and a lever on the end of each shaft, so as to apply the force to the wheel assembly at the proper place. The wheel assembly pivots on the output crank, and causes it to turn.
The wheel assembly is held in relation to output crank, by the wheels, running on the inside surface of the wheel housing.
The magnetic fields and the wheel assembly turn together. (same direction, same rpm.) "
sarmasio
Did somebody figure out this one yet ?
sarmasio
I think the machine from the
http://gigadron.com/
fits the description of this system.
regards,
sarmasio
