German magnet motor
Started by Omega_0, August 15, 2008, 09:49:55 AM
CLaNZeR
Quote from: pese on August 17, 2008, 01:07:30 PM
Attention at the 4 Magnets that are in your design "INLINE" next by next
BUT at "the origine motor"
   they are offset ordered.
This cane produce an great differnce in working ...
Pese
Yep I am making a ARC holder to position them in different ways, more to come yet :)
Cheers
Sean.
http://www.overunity.org.uk
dani1
Clanzer,
In your video you are testing the magnets of the v-track with another magnet. Both Tracks are appelling. In the V-Track of the original video one Track is N, the other S
dani
Quote from: CLaNZeR on August 17, 2008, 01:09:00 PM
Cheers
Sean.
Your first hand aided rotation made me think of a new design. I'll post a rendition later on.
CLaNZeR
Quote from: dani1 on August 17, 2008, 01:40:00 PM
Clanzer,
dani
Hi Dani
The two tracks on my rotor have N one side spiralling outwards and S the other side spiralling outwards.
Cheers
Sean.
Shanti
@CLaNZeR: Wow, just visited your site, and I have to shout a big: RESPECT for your continuous work!
Did you also try the LaFonte design? For this is the first I actually think could really work, as it uses the force developed perpendicular to the field.
See here: http://peswiki.com/index.php/OS:LaFonte_Perpendicular_Magnetics_Motor
I think, if you attach a large flywheel and mount some mechanics, it should even be possible to make a passive device on this principle.
About this german motor principle. I think the key point is, to have as much stators as possible. If you think about it, if one stator is at the sticky point, it will only get past it, if the force developed by the other stators (which are currently obviously not at a sticky point) is stronger. So more stators should actually help. With 2 it will certainly never work! As the other stator surely does not have the power to get the other one past the sticky point. Actually you could calculate if it is ever possible, even with an infinite amount of stators, so that all the non-sticky stators develop more force, than the current sticky one.
A simple try would be: Take one stator and measure the force exhibited on the rotor at different rotor positions. Then you will quickly see, if it is reasonable that some stators together bring more force than the current sticky stator.
