pyramid, clockwise spin, CCW spin, saltwater, air, and sand.
Started by nitinnun, August 16, 2008, 04:21:41 PM
nitinnun
this is the heart of the reaction.
saltwater allows a spin,
to be stored in one metal,
yet still be "connected" to the other metal.
THE REST of the device, just collects/generates CW and CCW.
except maybe for the two coils. which might have a diode effect, like drannon said.
which would explain why the CCW coil had more turns, than the CW coil.
nitinnun
this is the heart of the concept.
the steel frame attracts/stores CW.
(water in the air, generates this CW).
the copper core attracts/stores CCW.
(normally the sand in the ground, generates CCW. but in this case, the CCW seems to be generated from the steel, and from the oxygen/potassium/calcium, in the gypsum side boards).
one metal to attract CW,
the other metal to attract CCW.
trawoger had copper and graphite touching the saltwater, BECAUSE NEITHER OF THOSE RUST IN SALTWATER.
otherwise, it would have been copper and steel in the saltwater.
nitinnun
i'm going to try this copper core.
i can do far better than this. but this should be in agreement with the "energy effects".
it is:
1 big copper loop.
1 smaller copper loop.
4 plastic bottle tops, to hold the copper loops apart.
1 CW coil (8 turns), wrapped around the big loop.
1 CCW coil (21 turns), wrapped around the big loop.
(both coils ONLY electrically touch graphite/small-loop)
1 graphite stick, bound by copper wire, to the small loop.
(graphite does NOT electrically touch big loop. only touches small loop)
1 wire, connecting the CW coil, to the graphite rod.
1  glass pan ($7), to hold the sand and saltwater.
(glass is made of sand. and sand is immune to saltwater corrosion)
(sand/saltwater, will touch loops and graphite)
the big copper loop, will be connected to the steel frame, by a wire.
the CCW coil, will be connected to the capacitor/multimeter/fan.
Drannom
Hi Nitinnun
i have question for you, i understand your CW and CCW explanation, the question is : do you think your pyramid will resonate or not ?
from my point of view your sand and water are already resonating at their own molecular frequency, so if they emit some dc current it is probably like a pulsating direct continu current
i ask that cause i think that every molecules and atoms of this universe is under pressure by all the super light coming from all around them
then each atom or molecule with their molecular frequency may create pusalsating burst, a frequency so high that it is look like DC
it is possible that your coils are match with thoses molecular frequencies
heuuu i know , my question is much like my own theory to explain why your CW and CCW effectivly turn like vortexes
the coils in your set up will get meaning only if some high frequency DC occur, from my point of view
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
