Electromagnet power transfer question.
Started by nwman, August 20, 2008, 12:35:51 AM
nwman
Also here is another design. Instead of the flux traveling through the other valve it passes through the center connecting bar. As you can see when the valve is on the bar it is attracted and when it’s off it falls off. If you pulse one side then the other the polarity of the bar [C] in the middle should alternate creating AC. However the core material inside the primary coils A and B will suffer from polarity saturation if the Hz are too high and don’t give them enough time to lose their polarity. See video attached.
Also check out this thread I started: http://www.overunity.com/index.php?topic=6010.0
Tim
Video: http://www.abcwag.com/PC020030.MOV [8.6MB] It takes a while to down load and will play in your browser.
nwman
Quote from: TinselKoala on November 10, 2008, 10:42:34 AM
You might be interested in Flynn's work, if you aren't already familiar with it.
http://peswiki.com/index.php/Directory:Joseph_Flynn%27s_Parallel_Path_technology
Thanks, I am familiar with his work and I'm currently working with his idea in this thread:
http://www.overunity.com/index.php?topic=6010.new;topicseen
Tim
