Clarifying bedini schematic
Started by guruji, August 20, 2008, 07:46:33 AM
guruji
In this schematic when he said add as many slave coils as you want he meant to add a coil only or with a transistor and diodes?
Any help please?
Thanks
marcusishere
You need a transistor and diodes for each coil. The coils strands could be wound round the same core to make a fat coil and eliminate the need for carelful timing. I was going to make a coil with 3 power strands and 1 trigger strand but never got round to it. Attached is the circuit diagram :
guruji
Thanks Marcus is there a way to do two coils and trigger to one transistor cause I already did the circuit.
This one I do it on another motor.
Do you know of other guys who did this?Does this charge more faster?
Thanks again Marcus.
marcusishere
I don't know if it's possible. I recommend you join the yahoo group MonopoleMotor and ask there because there are guys much more experienced then me there.
There are guys in MonopoleMotor who have told me you'll get much faster rpm so that'll mean faster charging. Also you'll get stronger radiant pulses because they are stronger if they happen at the same time. That's how they persuaded me to put all three strands on the same coil. I would have done it but I've got interested in building a window motor instead. I might come back to it later though.
guruji
I had built the multicoil bedini.It's giving good BEMF.
Thanks Guys for help.
