IST'S M.A.M.K.C.
Started by innovation_station, August 20, 2008, 08:09:28 AM
innovation_station
M.A.M.K.C
stands for
magnetically activated motionless kick coil   ;)
out put far excedes input....
more to follow...
ist
this is my ss non mechanical battery charger... ;)
it can be made variable  ;) to tune it to correct freqs...
innovation_station
the device i spoke of
ist
Michelinho
Hi innovation_station,
Nice, I have also seen the SSG wheel as a commutator, it has nothing to do with much of the concept. The spinning vortices induce noise in his circuit and a low level output for his timing signal.
Great work,
Take care,
Michel
innovation_station
well did some tests on this unit it runs fine no heat or crap like that
makes noise   annoying.....   freq must be higher currently set adj 100ohm - 5k   problem at 5k...... pot melted down over a long peroid of time    have to work on that ....
in put 12vdc solar battery  deep cycle   output battery is tied to primary  1 feed and 1 return
out put is 100vdc and 33vac  after a bridge rectifier   b4 bridge dc volts are 70vdc peek  it flucuates a wee bit .....
after 1 hour of run time all i could read from my primary was a decrease of .01v   i did not mesure the charge ......   no need    when it is connected to the output battery i usualy get an incease of .4 v  across my out put battery   how ever i found for some reason a hv spot in the system i have been shocked 2 times from this unit....
the last time was verry intence  both arms   can you say NUMB......   oouch!!
the really odd thing was this.....  i was fiddleing with a termanal on the feed bat and a termanal on the out put chargeng battery ........
at the same time .....
just too strange.....
be careful if you play with this unit....   it bites darn hard
ist
innovation_station
i was able to get this to run on a 9vdc battery ....
also added a 10 k pot....  works ok on the lower voltage so far
i was able to tune it to a sweet spot of the coil .....
how do i know?
my 120vac 3ma max n2 with a resistor across it  lit up   else where in the freq range no lite......
ist
ok  also i notice when it stops working loose connection or somthing....  YOU MUST SHORT THE COIL ON THE PRIMARY FOR SOME REASON B4 IT WILL START AGIN    strange.....  this device is verry  lould as in you can plainly hear the coils sound....  when you turn the pot
i did not mesure the freq of the sweet spot i suspect it is lower freq...
ist
seams tricky to find with a 10 k pot  hummmmm  the sweet spot
