A possible similitude...
Started by iacob alex, August 22, 2008, 10:00:33 AM
iacob alex
     ...a potential easy to understand working ,design principle of a gravity powered device can be the well known LC oscillator.
       All that we need is a symbol transfer,from electricity into mechanics:
   -working voltage (power supply)  becomes gravity level
   -voltage pulses become gravity waves,pulses...the output that we need
   -electrical and magnetic fields can be gravity and rotational inertia
   -L and C elements become...???...this is the point!
   Take it as a sketch idea,nothing more.
      All the Bests!  /  Alex
dieter
"-voltage pulses become gravity waves,pulses...the output that we need"
I don't really understand - wouldn't you need electricity for that? Probably a diagram or picture would be helpful.
iacob alex
        Hi Dieter!
  Similitude is outward appearance,likeness,close resemblance.
  So,no electrical "sight".
  The electrical L and C parts,become mechanical parts..that's all way of thinking.
  The charge-discharge process of energy can be imagined as pure mechanical.
iacob alex
       Hi Dieter!
    Your question( august 2008) can be answered better now (march 2009),if you take a look at    www.veljkomilkovic.com  then click on the text of Jovan Marjanovic(Key of Gravity Machine).
    Then,it was for me a kind of diffuse understsnding...now I have more clarity.
    A possible similitude of elementar mechano-electric abstracts:
      push,pressure/voltage
      movement,velocity/current
      lever+fulcrum/transformer
      pendulum+fixed fulcrum/open circuit(no current)
      pendulum+mobile fulcrum/closed circuit(we have current,...so a current generator)
  As Marjanovic says,if we manage to modify the swinging motion of the pendulum into a spinning one,we can get out energy from this pulsating mechanism.
iacob alex
  ... from electronics can be a relaxation oscillator:all that we need is a transfer of the groundwork.
      A relaxation oscillator is an oscillator in which a capacitor is charged gradually and then discharged rapidly.
      Mechanical capacitor is a flywheel type.
      The capacitor is charged through a resistor(current source).
      The torque difference (in a long arm-short arm arrangement,with two equal masses), acts as a current source.
       The supply voltage is the gravity potential between two levels.
       In parallel with the capacitor/flywheel  is a threshold/latch device.
       An illustration you can find at    www.geocities.com/iacob_alex   then click at "Some_Drafts"/text013.jpg  with the title "Free Gravity Rolling 01"...a rolling wheel on the ground surface.
