Emulsifying Brown's Gas
Started by goldenequity, August 24, 2008, 05:39:29 PM
goldenequity
Quote from: gotoluc on September 04, 2008, 10:28:51 AM
WOW goldenequity,
you are doing great work here ;D  Where is everyone ???... Are we not interested in saving up to 50% on heating this winter ???... or is everyone here living in the South.
Come on everyone!... at least let goldenequity know you are reading his post and find them informative.
As soon as I have some free time this is what I will be working on as you know it is not far fetched science. You know it's going to work.
Enough said!... lets get the ball rolling ;)
Luc
Thanks Luc......
I think when the Plasma efforts integrate with this, it's going to really take off.  I'm trying to be patient..  ::)
Big Oil has tried to KILL all the fuel saving gadgets through the years by buying up the ones that work.... like the Pouge carb.... and have deliberately moved against VAPORIZATION..... by getting rid of the carburetors in our vehicles and re-formulating the fuel to suppress vaporization... (so we add Xylene etc.)
Well guess what.... this stuff should LOVE their injection systems and doesn't NEED to vaporize.... it just gets sprayed/atomized into the cylinders!  We already know and have seen BubbleTech's EM-fuel work!
I also believe we (through experimenting) can come up with an emulsion blend with gasoline that will work in EFI gas engines..... why not????
Cheers! ;D
randy
kremlin01
Golden-E. As Luc said " your doing a great job"
That patent' is a light in the dark, read that and it does'nt much immagination to agree it can be done, to our own needs, and spec:
in our own back yard.
Just now clearing some space in garage so I can  join the fun.
Many thanks, regards, Bren :)
pese
Ref:
Taking the Brown's Gas from a simple electrolytic cell with the output into semi-viscous fossil fuel liquid(s), where it is agitated to a  micron level and trapped as hydrogen and oxygen in a stable emulsion either in a batch or flow configuration.
Let's just make the creamy liquid and try burning it!  Grin
Brown gas (Watergas) is more than a simple elektrolysis (it need 4 volts per cell)
make gasoline/water emulions, it is easy.
to burn water with the gasoline make more energy
lot of people have done this before.some labors and
unversities have proof this up to 50% with gasoline aswell diesel.
Pese
goldenequity
@ Krem
Excellent!
@ All
Once we get this setup and recipe down..... I think a MOBILE setup could easily be made with the tank and pump in the back of a pickup!!!!!Are you out of work???? Cash poor?  ???
Build this setup in the bed of your truck and start your own processing and delivery service......help others/help yourself!!!!!
Freedom Works!!!!!  :) :) :)  Go for it and help us get this thing NAILED DOWN!
gourdman
 :D
Hi everyone just a note to let you know im here
  Great work everyone.  I have been following several of these threads and it looks to me that you are on the edge of a breakthrough.
I have been working on a couple of engines and just got the plasma spark working .
I just built hydrogen electrolisis cell.
I really like the idea of mixing the fuels and ignititing with plasma spark.
I just need to work on the electronics a little more
Getting the ignition timming right and building a pulse generator are taking longer than I thought
I'm slow but am having fun and making some progress.
Ill let you know if I get an engine running.
  Thanks everyone for all your hard work on this.
IM looking forward to see what this new mix will be capable of :D
  Gourdman!!!
