Aliens are coming October 14th 2008 Galactic Federation
Started by shooter001, August 27, 2008, 01:21:01 PM
Paul-R
Quote from: supermike on October 19, 2008, 07:37:46 AM
Provable sighting, no camera necessary.
I humbly predict that an invisible spacecraft of huge dimensions, (fill in your own numbers metric or imperial), will be hovering over (fill in your home town), today, (and for the rest of the week).
If you look out your window at the sky and can't see it, that's it!  :)
That's amazing, Supermike. I couldn't see it as well. I felt its presence, and it was
big, as the actress said to the bishop.
Paul.
z.monkey
Quote from: Gheller J on October 23, 2008, 07:51:14 AM
The “Ancient Solfeggio” Ascension Frequencies are frequencies that can start your ascension process.
Howdy Geller J,
Sound is not the only thing that can effect you in this way.  Stimulus can come through any sense including EM energy.  The catalyst is not important as the effect.  You don't need to download 100MB file to do this with sound.  Setup you frequency generator to run at those rates and attach a speaker.  A piece of computer software can do the same.  Or your synthesizer or a guitar.  Better yet, build a circuit that can generate those frequencies, like a PIC project...
OK, Mo Later...
Goodwill to All, for All is One!
Gheller J
Quote from: z.monkey on October 23, 2008, 11:43:05 AM
Howdy Geller J,
OK, Mo Later...
Hey Z.mon
There r a lot of these freqs over the youtube but if you listen 2 those & this theres a huge huge difference! this actually does something  I cant explain d exact feeling but you can actually feel d pounding inside your head along with the music like he says and u hv other ambience tracks of an ocean and birds chirping running in d background n dis is soothing. U only need to compare to see the diff.
Abt the synt, i think their output is tuned to the 12 Tone Equal Temperament and not to Just Intonation.
I've tried d frequency generator part when i was downloadin this file, but these a lotta diff from d posted file to what is generated, compare the diff n you'll understand what im sayin, so I felt why reinvent d wheel when its already done ;D
Gh. J.
Gheller J
I was sent d followin whe I asked what n how to find more about d followin
"Looking at the definitions of each of the original syllables, using hidden entries from Webster’s Dictionary and the Original Greek Apocrypha"
I received d pasted info below
and about the best way to listen is by supposedly using in-earphones n he gets d best output on his 'Sennheiser in-earphones' on an ipod. Theres a pic he sent along of what he uses n wich I attached.
  Gh. J.
From: "Healing Codes for the Biological Apocalypse"
Evolution of the Gregorian Musical "Solfeggio" (Scale) form Initially Six (6) Notes
The Original Solfeggio
1. Ut - queant laxis
2. Re - sonare fibris
3. Mi - ra gestorum
4. Fa - muli tuorum
5. Sol - ve polluti
6. La -0 biireatum
The Earlier Modified Solfeggio
3. Mi - ra gestorum
4. Fa - muli tuorum
5. Sol - ve polluti
6. La - biireatum
7. SI - Sancto Iohannes
The Current Modified Solfeggio
1. Do - queant laxis
3. Mi - ra gestorum
4. Fa - muli tuorum
5. Sol - ve polluti
6. La - biireatum
7. TI - Sancto Iohannes
(From Page 177: Fig 5.6):
The Secret Solfeggio Frequencies: Sound Vibration Rates for Creation and Destruction:
1. Ut = 396 = 9
2. Re = 417 = 3
3. Mi = 528 = 6
4. Fa = 639 = 9
5. Sol = 741 = 3
6. La = 852 = 6
(From Pages 166 & 167):
Definitions of Tones in the Latin Solfeggio Including "Hidden Entries" From Webster's Dictionary
Note 1: There are typos on this page. Most of them come from the book, as I typed it exactly as in the book, as best as I was able.
Note 2: Emphasis added by italics in each definition denotes special relevance to the book.
UT-quent laxis
1. a syllable used for the first note in the diatonic scale in an early solminzation system and later replaced by do. 2. the syllable sung to this note in a medieval hymn to St. John the Baptist. <Gk. -Gamut- 1. the entire scale or range; the Gamut of dramatic emotion from grief to joy. 2. the whole series of recognized musical notes [1425-75]; late ME (Middle English)><ML (Medieval Latin)-contraction, of Gamma, used to represent the first lowest tone of (G) in the Medieval Scale Ut, Re, Mi, Fa, So, La, Si. <Gk - Gamma- 1. the third letter of the Greek alphabet. 2. the third in a series of items. 3. a star that is usually the third brightest in a constellation. 4. a unit of weight equal to one microgram. 5. a unit of magnetic field strength equal to 10 to the fifth power gauss. (quent: needing), (laxis: loose; axis-an affiliation of two or more nations. Also Axis Powers.)
RE-sonare fibris (Res-o-nance)
1 a: the state of quality of being resonant. b(1) a vibration of large amplitude in a mechanical or electrical system caused by a relatively small periodic stimulus of the same or nearly the same period as the natural vibration period of the system 2. the prolongation of sound by reflection; reverberation. 3a. Amplification of a source of speech sounds, esp. of phonation, by sympathic vibration of the air, eesp. in the cavities of the mouth, nose and pharynx. b. a characteristic quality of a particular voice speech sound imparted by the distribution of amplitudes among the cavities of the head, chest, and throat. 4a. a larger than normal vibration produced in response to a stimulus whose frequency is close to the natural frequency of the vibrating system, as an electrical circuit, in which a value much larger than average is maintained for a given frequency. 5a. a quality of enriched significance, profundity, or allusiveness; a poem has a resonance beyond its surface meaning. 6. the chemical phenomenon in which the arrangements of the valance electrons of a molecule changes back and forth between two or more states. (in percussing for diagnostic purposes) a sound produced when air is present [1485-95]; <MF (Middle French), <L Resonantia, Echo=Reson (are) to resound + Antia-ance. (Re-a prefix, occurring orig. in loan words from Latin, use to form verbs denoting action in a backward direction, Action in answer to or intended to undo a situation, or that performance of the new action brings back an earlier state of affairs. (fibris: fibre string, vocal cord.)
MI-ra gestorum (Miracle)
1. an extraordinary occurrence that surpasses all known human powers or natural forces and is ascribed to a divine or supernatural cause esp. to God. 2. a superb or surpassing example of something; wonder, marvel {1125-75}, ME<L Miraculum=Mira(Ri) to wonder at. fr (French): sighting, aiming to hold against the light. (gestorum: gesture; movements to express thought, emotion, any action, communication, etc. intended for effect.)
FA-muli tuorum (Famuls.)
... plural Famuli, 1a. servant/s, or attendant/s, esp. of a scholar or a magician [1830 - 40<L (Latin), servant, of family. (Tourum - quorum - 1. the number of members of a group required to be present to transact business or carry out an activity legally. usu. a majority. 2. a particularly chosen group. [1425-75;<L quorum of whom; from a use of the word in commissions written in Latin specifying a quorum.)
SO-lve polluti (So-lve')
1. to find the answer or explanation for; clear-up; explain; to solve a mystery or puzzle, to work out theanswer or solution to (a mathematical problem. ) [1400-50, Late ME<L Solvere to loosen, release dissolve=so-var, after velarl, of se-set-luere to wash; (see Ablution.) Ablution n. 1. a cleansing with water or other liquid, esp. as a religious ritual. [1350-1400]. (Pollutii-pollute-luted, 1. to make foul or unclean,)
LA-bii reatum (Labi-al)
1. of pertaining to or resembling a Labium. 2. of pertaining to the lips, 3. (of a speech sound) articulated using one of both lips. 4. of or designating the surface of a tooth facing the lips. 5. the labial speech sound, esp. consonant, [1585-95]; ML lingual. (reatum - reaction - 1. a reverse movement or tendency; an action in a reverse direction or manner. 2. a movement toward extreme political conservatism; 3. a desire to return to an earlier system or order. 3. action in response to some influence, event etc.; 4. a physiological response to an action or condition. b. a physiological change indicating sensitivity to a foreign matter.) 6. mech. the instantaneous response of a system to an applied force, manifested as the exertion of a force equal in magnitude, but opposite in direction, to the applied force [1635-45].
SI (Sancte Johannes)
1. a person of exceptional holiness, formally recognized by the Christian Church esp. by Canonization. 2. a person of great virtue or benevolence. 3. a founder or patron, as of a movement. 4. a member of any various Christian groups. 5. to acknowledge as a Saint. Canonize [1150-1200]; ME Seinte. Canon: 1. an ecclesiastical rule or law enacted by a council or other competent authority and, in the Roman Catholic Church, approved by the Pope. 3. a body of rules, principles, or standards accepted as axiomatic and universally binding, esp. in a field of study of art. 6. any officially recognized set of sacred books. 10. the part of the mass between Sanctus and the communion. 11. consistent, note-for-note imitation of one melodic line by another, in which the second line starts after the first. (axiomatic). 1. pertaining to or ofthe nature of an axiom; self-evident. 2. a universally accepted principle or rule. 3. a proposition in logic or mathematics that is assumed without proof for the sake of studying consequences that follow from it.
shooter001
