Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
Drannom
Quote from: broli on September 20, 2008, 11:34:37 PM
Maybe he was drunk or high  ::). Btw don't local glass formers (if you have a local one at least) have high temperature ovens? Maybe some deal could be done to make this under some personal science project disguise  :P.
yes, i was drunk and high
sorry resonanceman, in the electrinium there is a gearing system to push or pull the crystal while it is growing, that's right
when i saw some gearing to push a cristallizing crystal in electrinium, i do not care, i forgot, cause i focus on a very little system to cristallize something more simple than the compicated receipe
i have grown many crystals, and i look to a simple way to test the theory of the electrinium, i look for a very short cristallization, (with no gear), just little electrinium crystal with steel, something easy for all to proove the theory
and i am proud of you all trying the complex method, i prefer to test it in a simple way
the wine was red De Noiret, and the high was an homemade vegetable...
sorry resonanceman, in fact i was going to sleep right after my above post
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
So guys besides the talking where does this bring us now? What can we start that is already possible without needing fancy tools. Maybe at least the collection of the ingredients, the container and/or an electrification setup that would align the molecules.
z.monkey
Howdy Y'all,
I wish I was high.  I have been denying my habits for spiritual enlightenment.
Resonanceman, the reason the silicon mixture is pulled and not cast is because you want a crystalline structure to grow.  If you extrude the mixture through a tube is you basically get a glass structure which is almost crystalline instead of a quartz structure which is a real crystal.  The molten silicon is the viscosity of a dense clay.  Imagine when you have seen molten glass being worked.  It is a red hot mass of puddy which is very hard to work.  The crucible would have to be continuously heated and a blast of cool air would allow the top of the mass to begin to solidify, this is where you stick the seed, and begin pulling the cooling crystal out of the crucible.  Electrinium will have a little different characteristics.  There will be iron, silver and borozon in the mixture as well.  This will change the melting point, the melted viscosity, the cooling rate and the pull rate.  All of these variables are unknown at the moment and the precise ratio of elements is also unknown.  We would have to make our best guess, run a batch and test it.  Then do it again and again and again and again....
Drannom's idea about using carbon and iron (steel) to do this is intriguing.  We can go to the hardware store and buy steel, no need to fabricate it.  To activate, and align, the iron carbon molecules we would need to apply a direct current to a piece of steel.  Then heat it up to the point where the molecules are mobile enough to reorient themselves.  When the molecules align they will start to conduct.  Mr. Summera said that when the material starts to conduct current we would need to remove the direct current and attach a load resistor.  The resistor can be attached at the beginning of the process, then when the material starts to conduct then we simply remove the direct current source.  Then allow the material to cool with the load resistor attached.  Once the material is cool then the molecules are set and the steel becomes a permanent battery.
There are also other materials which have the same properties.  You would basically pick and element and find its polar opposite then bond them together in a process.  Some may be easier to work with than the Electrinium.  I am not a chemical engineer so picking those materials is not my area, Drannom may be better at doing that.  I am more of a manufacturing engineer.  I develop processes where we can mass replicate something, usually electronics and electronic products.
Batteries are the cheapest, easiest, most profitable, and least environmentally friendly way of exploiting the phenomena of elemental duality.  They produce electricity for a limited time and then they are used up, have to be recharged and thrown away.  If a little more thought was put into the battery it could be a powerful energy source.  I know why this was not done, Profitability.  Profit ruled the 20th century.  If a company started making batteries that never wore out that would hurt future sales.  This is a very selfish and shortsighted point of view, but I can understand it.  The same thing happened with many manufactured products.  So there is a massive body of information on batteries and we can glean from that body of information everything we need to make permanent batteries...
Blessed Be...
Goodwill to All, for All is One!
resonanceman
Drannon
No offense taken .
Quote from: broli on September 21, 2008, 06:31:19 AM
Broli
I  don't know anything about  chemistry ......I will have to  trust  others to that.
I am good at finding   visualizing   and  basic mechanical design .
I am  good at finding ways to  get machines to  do what  it is needed .
I do  think there is a lot of potential  in Electrinium
I do think  that  a proof of concept  experiment  would  be  very valuable .....even  if it didn't put out much power.
A few general  questions for all.
When they make glass  fibers  for   optical  networking  they   deposit  the  glass in a different form
I don't remember what they call it  .......but it is white and chalky .       As I understand  there  are  different  impurities  in different parts of  this form.
they then heat  the whole thing up and  it fuses into a clear mass  of glass.
When they  draw the fibers   the  impurity's  keep  the same  cross section so they can  have  different optical  characteristics   in the core of the fiber than in the outer part.
Can something  like this  be done   when  making   Electrinium?
Electrinium  requires an electric  current  to align the  molecules  in the final  step .    Is there a way to add  an  electric  current to the  crystallizing  process ?
Could  adding   a current flow make   any of the  possible   combination's  materials more practical?
I read  somewhere that if  you  electroplate  layers of different  metals thin enough on the same  object  the coating  will mimic  a solid  alloy
Could  an Electrinium crystal  be  grown in layers like that?
gary
z.monkey
Howdy Resonanceman,
If we align the Electrinium molecules during the crystal growing process then we have a massive activated crystal that we would need to be sliced up to make the wafers for the batteries.  This would be hazardous.  It is better to activate the Electrinium after the batteries have been manufactured.
The electroplating process is intriguing.  You basically build the battery one molecular layer at a time.  Semiconductors are manufactured in this methodology.  Where you start with a silicon substrate and build the circuit from the bottom up one layer at a time...
Blessed Be...
