Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
wizardofmars
Quote from: z.monkey on September 26, 2008, 06:21:43 PM
Howdy WizardofMars,
Your questions are irrelevant.  Who wrote it and where it came from is totally irrelevant.  What matters is the content.  Which you apparently have not read.  I am not going to make an effort to argue with you since I already know the value of the content.  Don't bother us anymore...
Are you going to ignore my question on NESARA?
It is better to light one candle than to curse the darkness. - Chinese proverb
z.monkey
Quote from: wizardofmars on September 26, 2008, 05:33:39 PM
Wow. You believe in NESARA? I've always wanted to meet someone who did. That explains a lot!
For those unfamiliar with the NESARA conspiracy theory -> http://en.wikipedia.org/wiki/NESARA_conspiracy_theory
There is also a great documentary on NESARA believer groups in Utah called 'Waiting For NESARA' which will blow your mind.
Howdy WizardofMars,
You dump on everything else so I am not surprised that you would dump on NESARA also.  Yes I believe in NESARA.  I don't care what you think about it either....
Blessed Be...
Goodwill to All, for All is One!
ian middleton
G'day all,
@nievesoliveras:  Have you had a look at the "crystal power cell by JH" thread. You may find it interesting.
Cheers
Ian
nievesoliveras
Hi
@Ian
Yes I have seen the JH batteries. But I have not been able to replicate them.
I dont have the correct procedure and formula.
Jesus
jeanna
Hi guys,
Most of you feel like friends from other threads. No surprise here. ;)
I read all the way through so I wouldn't be duplicating any ideas, and at the very end Jesus mentioned what I wanted say most.
But I would like to expand it a little.
In Gary's plan with the rods that need to be melted together, OR the spot welding, EITHER one could use the Brown's gas to weld or spot welt these non similar metals together so you can see if this is the right track to follow.
Earlier this summer, I enquired about purchasing a welder from one of those companies. Darn,  they never replied.
So, I will be making a small thing that will look like the HHO bubblers for cars only with a welding tip. This will be easy. (I just need to clear some space from other things - crystal battery included!)  ;D  ;D
Gary, maybe you could make one there where you are.
@ Drammon
My other thoughts have to do with your experience with Alum pyramids.
Maybe you could produce a bunch of seeds??
I think you should ask the group about Aluminum again. After all this Crystal Alum Pyramid is made from saturated aqueous solution of potassium aluminum sulphate - Alum- that precipitates by landing on an alum seed and continuing to grow.
And it is the vortex flow of the water solution that seems to do the magic.
Oh, yes, and the heat of a light bulb to keep more alum in solution.
I'd call this low budget and easy. I think this may be a really good place to start.
The other thought/question I have for you Drammon, is would you be able to devise a way to make silicon crystals using sodium silicate?
It is very thick so it would be harder than the water you use for alum.
Zmonkey,
What is it about silicon that makes it hard to make a crystal?
Nature forms these crystals all the time.
I can't think of a method nature uses to draw out a thread to make a crystal.
Do you know what is required as a minimum?
Nature does have a lot of force and heat from time to time, but this manufacturing process seems way too complicated. I wonder if it is really necessary for this? OR really I wonder what parts are the necessary parts?
I have more questions, but I want to actually read the whole electrinium pdf first.
Oh one more thing,
I came here to find out what those on this thread found out about electrinium, because I want to start a thread about the thought that keeps burning that the ancients used the baghdad "battery" to make HHO. I am wondering if that unit that was found was really filled with carbon or electrinium and connected as an electrolyzer to make a slow constant process of HHO; so, I am glad I am reading this thread, and may we will once again contribute to each other's ideas and experiments!
thank you all,
jeanna
