Steve Marks Device May Be Authentic
Started by Freedomfuel, October 23, 2005, 04:49:22 PM
Yes, I agree, most of the stories about him are just made up by disinformation agents.
He also was harrassed. I tried to find people who were involved and all only don?t want to say anything about it.
Also the guys who published the things about him can?t be reached anymore or they don?t answer emails...
He also wrote me lately that he was harrassed by agencies and had fear about his live.
So we will see, what will still come out of all this soon. I hope he will publish soon some secrets
about his invention.
Regards, Stefan.
giantkiller
Snap, crackle, pop...
The basic Patent is Tesla's 390,721. The patent exists for the mechanical. The full implications are not fully documented.
Step 1: a 4 coil toroid that generates a rotational magnetic field.
a frequency above 40k hz generates free power across another coil.
Proof: Tom Bearden stated that a spinning magent operates exactly like a gyroscope. The same laws of physics apply.
Proof: Steven Marks demo'd the effect with his 3", 6" 17" coil. 5k hz is too low.
Step 2: A duplicate 4 coil toriod mechanically meshed with the first one, operated in reverse order.
The easiest way to get the mesh is to use dual conductor or speaker wire.
Proof: Steven Marks has 2 on switches on the 17" coil. Counter rotating magnetic fields produced by 2 intermeshed 4 coils rings.
Now when both rotation speeds are the same the effect is one crossover point some where on the coil. This obviously can be used as an x/y navigation during Levitation.
By varying either speed ever so slightly precise shifting control can be gained.
So how do we achieve higher interference rates? 2 ways: increase the current to the coils (this creates more flux lines) or up the rotation speed  (This causes more lines of fluxes to cross each each other). Or, oh my God, do both!
Now we know that any rotational speed higher than 40k will radiate magnetic fields, like radio, microwave.
By putting the higher speed emminations in a toroid we end up with a magnetic compression engine. The center is a twisted, highly compressed magnetic force that produces a magnetic black hole.
In the compression center as the lines of flux are highly enregized and cut through each other both but can't cross center, the toriod ( with a twisted center) becomes a
magnetic ball that at different speed causes really fantastic anomolies. Would you care to speculate, like levtation, cloaking, interdimensional traversing of space.
We are talking huge field effects. These effects are already shown at the shoutwire site for the SETI alien contact video.
My avatar is the next coil rendition. And how do I get the high current into it. I will wire one coil to the 1,2,3,4 spark wires of an autombile and run the 1,2,3,4 of the other coil to
another vehicle to run at a different speed. The RPMs won't get above 40k on the ring rotation speed but the interference speed should be high enough. The only problem is you show up on radar.
So be cool.
On another note:
The hutchison effect is the application of a 2nd frequency against the base frequency of our magnetic environment and another frequency imposed against that. The effects are caused by the line of flux cutting across each other. Anything in the way gets altered, weight, atomic makeup.
The Lifter technology proves levitation. The instability is from being on the edge of the field. It wil never be stable because it is on the end of the field.
I made a previous statement to the release of information to the world as I get it. I am up all 24/7 in spells analysizing and deriving. Anybody out there taht doesn't want to believe or understand then that is your problem. None of the findings here break the laws of physics. Stay on board. See the SETI contac video!
I don't want to sell this because I don't want visitors. And nobody can sell this. This knowledge is now public domain and the government doesn't want that.
Once again, cut the crap theories. The force, Luke, is called the magnetic field between the lines of flux, not aether. Start your on new age post and stay out of reality.
The gauntlet is thrown.
I slay giants, lest I die in darkness. 8)
Oh, and by the way.... You heard it first! Now tell your friends and pass it on and lets get this show on the road.
kames
Hello giantkiller,
Hmmm?, interesting. The uniqueness of Tesla rotating field is that the coils (magnetic poles) are placed along the perimeter of the toroid and not towards the center of the toroid, like in most of the electric motors. Despite that, a compass needle is still rotating even when placed in the center of the toroid, which is based on the theory should not have any magnetic flux getting outside the magnetic core. Did you see, I believe SciFi or History channel, a movie about Tesla museum with a rotating compass needle? There are some reports and patents, even very recent, that the net energy gain is obtained by moving around the magnetic flux in opposed to crossing it. Not sure if this is the case for Steven Mark, he is using a permanent magnet, but who knows.
Not a problem for me to use 40 kHz, however, using two rotating fields in different directions is also worth of testing.
Not bad at all. If you have any anomalies recorded, can you tell us about it?
Kames.
starcruiser
Giantkiller,
Indeed very intersting. What are you using for the core of the torrid coils? is it ferromagnetic or a wood or plastic form?
So from what you are saying in your post you would pulse the coils in a clockwise and counter clockwise direction to create the interference points. So as I understand it the pulses would be a 0, 90, 180 and 270 degrees to create the moving fields. Am I understanding your concept correctly?
Thanks for the ideas.
Carl
Carl
