Steve Marks Device May Be Authentic
Started by Freedomfuel, October 23, 2005, 04:49:22 PM
Elvis Oswald
Giantkiller...  Good ideas - I thought I'd suggest a couple of things. :)
There's a thread hear somewhere - someone was making coils with his son.  I forget the name of the coil... but it's basically wound by taking a very long wire and "folding it in half" and then again, and again... VVVVVVVVVV <--like that... or V in your case of a two-wire wrap... a 200 ft piece would get you a 100ft dual-conductor/opposing- current winding.
I also wanted to ask if you were creating a resonate LC circuit tuned to match your input.
Peace :)
Elvis Oswald
Quote from: Freedomfuel on October 23, 2005, 04:49:22 PM
1.Someone who is determined to rip off investors is hardly likely to invest a lot of money in laboratory facilities.
2. In the video Marks claims that the source of the energy his device extracts is the earth's magnetic field.  This is, I believe, correct and it is also confirmed by a statement by one of the Disclosure Project's 'insiders'.
3. The device only works when the axis of the coil is vertical and it ceases to work when the coil is turned upside down.  This is consistant with the principle that such devices function by beaming a signal into the ionosphere which is reflected back magnified.
4. In the video Marks demonstrates a bright flash of light when the output of his coil is short circuited.  This bright flash of light is a phenomenon associated with magnetic current or 'cold electricity' as it sometimes called.
5. The strange inertia effect when the coil is moved in one of the videos suggests that a motor driven commutator inside the coil is being used to switch on and off segments of the coil.  See the animated giff from the same archive for ideas how such mechanical commutation could be used to create a rotating magnetic wave from a torroidal coil.
6. The fact that a magnet needs to be connected to the coil in order for it to work is typical of all such devices since they require pulsing of permanent magnets.
All very good points.  :)  I have been skeptical of it myself... but Steven does not appear to be gaining anything financially from this... and I can't think of any other reason to try and hoax this.
On #5 though - I don't agree that there's a mechanical force involved... ie "no moving parts".
Also... are there steel wires in his device??  The steel would become magnetized as long as the magnet was attached... if that's what it took to make the coil more sensitive... or make it "appear" closer to half-wave in size... that would explain why the device turned off when the magnet was pulled.
This makes more sense than the magnet creating current in the coil to "kick"start the thing... which I have thought, and is a good theory... but I like this one better :)
Does a magnet touching steel change the resonance of the steel?  I guess it would.  And technically it's not so much the size of the antenna... it's the mass... and the mass makes it resonate at a certain freq.
Antennas do need to be related to the size of the wave... but the resonance of the mass is what's important... it just happens that a size related the wave you want is the right mass.
A tank circuit shows anomolous spikes when the input is at the resonate freq.  Isn't this like the LC circuit in your radio... and the reason you never tune dead on a freq??  So if you tune dead on... your antenna didn't get bigger - you just made the radio a resonate LC circuit.
I guess my point is that magnetized steel may make a better receiver of the schuman freq.
Peace!
PaulLowrance
Quote from: Freedomfuel4. In the video Marks demonstrates a bright flash of light when the output of his coil is short circuited.  This bright flash of light is a phenomenon associated with magnetic current or 'cold electricity' as it sometimes called.
This type of flash matches high frequency arcing. We know that magnetic materials (soft, hard, PM's, any type) contain high frequencies typically from ~100 MHz to several GHz, but can be significantly lower. Most people are not aware of the tremendous energy exchange occurring per quarter cycle within such magnetic materials. This is Magnetocaloric energy. In some materials it's high enough to increase the materials temperature by 7 F per quarter cycle. That's a whole lot of joules. If our frequency is 50 KHz then that's 200000 quarter cycles per second. Enough to increase the materials temperature by 7 F * 200000 = 1,400,000 F in just one second !
In other words, the material radiates a tremendous amount of energy per quarter cycle, but also absorbs nearly all that energy. The trick is preventing the magnetic material from absorbing that vast amount of Magnetocaloric energy. This is typical ac current in a transformer or inductor. In legitimate "free energy" devices you'll note that in nearly every case there is an applied DC magnetic field, which flips the process and also sometimes can change it to half cycle energy exchanges instead of quarter.
Paul Lowrance
tishatang
Hi!
The coil my son and I built was this technique.
http://www.littlemountainsmudge.com/mobiuscontinuosknot.htm
We used about one half lb  number 16 guage magnet wire.
I could feel the slight kick  in my hand turning it on.
I don't think the mobius knot is necessay.  The important thing is to wind the looped wire with a drill to get as close to 46 degrees as possible.  That way the return current crosses at 90 degrees as in the caduses coil.
This 90 degree crossing is what supposedly creates a scalar wave.  Also, some say one fold is all that is necessay.  If you have fine wire, fold it twice.
tishatang
Elvis Oswald
tishatang... I think I might experiment with trying to twist a cable around another cable - to make two concentric coils... and see what kind of power I can get on the secondary with different configurations...
