Pier Luigi Ighina
Started by tak22, September 11, 2008, 05:34:18 PM
tak22
I've resumed interest in the work of Pier Luigi Ighina, but as before I'm finding it difficult to
find good information. Has anyone collected any info beyond the basics that are on the web?
I'd appreciate hearing from anyone that has documentation to share.
I've included a couple of links and quotes so you know who and what I'm talking about.
From here: http://www.svpvril.com/ighina/magatom.html
QuoteWhat follows is the resumed and translated text of the original Italian book
“L’atomo magnetico” (1954) by Pier Luigi Ighina. This book is the only one
written by the scientist.
When the scientists first started studying the atom, they soon realized that
when it was excited by the light atom, it would just disappear in the light.
So they started to excite it with strong magnetic fields and strong electric
tensions, causing the alteration of the atom itself. In fact, in Dr. Ighinas
opinion, electrons, protons, neutrons, positrons etc. are products of an
altered atom, so their laws are altered in respect to the normal atom.
By examining the atoms of different matter, he found out that every atom has
its own absorbing rate. From this discovery he made a scale of atoms of
different matter with absorbing rates, in relation to the light atom, from
95% to 1%. It took him 4 years of study to create this scale.
The other problem he had in observing the atoms was that they are also
disturbed by the surrounding atoms. In order to isolate the observed atom he
created some sort of a “wall” composed by different layers of atoms, setting
the ones with the maximum absorption (95%) in the inside close to the observed
atoms and then one after the other the different matter with diminishing
absorption rates (85%, then 75%, and so on until the 1%). With this idea he
was able to create some sort of canals that would take the motion away from
the observed atoms and make them be almost still. But there still was the
problem of having a stronger microscope. He invented a microscope (see later)
with which he was finally able to observe the atoms at a enlargement of 1.6
billion times.
Through his observation he noticed that the atoms had a pulsation and, with
every pulsation, a luminous circle would leave the centre of the atom and get
bigger moving away from it. The different circles would create some kind of
shield around the atom. He concluded that the atoms don’t oscillate but vibrate,
and that it is possible to divide its energy but not the atom itself. He also
noticed that after a while, the atom excited to its maximum by the light atoms
would explode, and after that there were two atoms. He called this phenomenon
the reproduction of matter. He observed that different matter have different
pulsations. These atoms, which he called “reproductive permanents”, are present
in all organic matter, while in the minerals the atoms don’t have any
reproduction unless they are excited from atoms with more power.
He tried then to observe the atoms of magnetite (until now he had been able to
do all observations with a resolution of under 1 billion times). This time he
needed to go over 1 billion enlargements to see these atoms, and as he saw them
they were moving a lot faster than the usual atoms and were a lot smaller. He
tried to stop their motion with his developed technique, but without success.
These atoms appeared to have a reproductive permanent motion which was much
faster than the others. Enlarging the atoms to 1.2 billion times he saw that
they were present in all matter, and especially in the air. He decided to call
them magnetic atoms. After long experimentation he was finally able to almost
totally isolate them. At this point he made another astounding observation:
while isolating the usual atoms would stop their motion, isolating the magnetic
atoms would accelerate their motion to the point of developing such strong
atomic energy that the surrounding atoms would be influenced. Since this
reaction was dangerous, he developed a particular substance composed by
different atoms and was finally able to isolate the magnetic atoms. By studying
it he found out that it was identical to the reproductive atoms with the only
difference that its motion was perpetual. Putting this atom in contact with
other different atoms he could observe the following: when the magnetic atom is
isolated it develops its maximum motion until it meets another atom of its same
motion sensitivity (pulsation); this atom starts to move and absorb pulsations
from the magnetic atom until it has reached its maximum motion; at this point
the two atoms go apart. In the meantime the atom has diminished the motion of
the magnetic atom, so the latter will find another atom with that new motion
sensitivity and transmit motion to this one until it has reached its maximum
motion, then detach and so on until the magnetic atom has reached its minimum
pulsation. But, since its pulsation is everlasting, it will raise again and the
whole process recommences. This way he discovered that the magnetic atom is the
one that gives motion to all the others.
After his ultimate studies of the magnetic atom he was able to group them into
two categories: if the atom starts its pulsation by contracting, it has got
negative properties, if its pulsation starts by expanding, then it has got
positive properties. He theorized that if it were possible to separate the two
kinds of atoms and put them together separated by absorbing atoms, one could have
a continuous and eternal production of electric energy.
And also: http://rexresearch.com/ighina/ighina.htm
tak
SineWave0
I've been studying Ighina's work for a while and have replicated a couple of his devices ERIM and ELIOS.
The best source of information on Ighina is from a man named Domenico Dati on Facebook.
He is in Italy and has been studying Pier Luigi Ighina for many years.
Here is the website pages:
Pier Main page on Fortunadrago.com (Italian site but translated)
Scroll down the page for the MANY links on Ighina's work and Many pdfs for download.
http://fortunadrago.xoom.it/main/?page_id=185&lang=en
Add me on Facebook.com/Verbelli
And Youtube.com/TheRealVerbz
--Jason Verbelli
tak22
Thank you Jason, that's a very informative site that Domenico has created!
For the ERIM and ELIOS did you find exact specifications or did you have to
work to the pictures? Can you relate any experiments and results you achieved
with them?
Is there one device of his that you feel is the most important for replication?
again, thanks!
tak
derekwillstar
Hi! Thanks Jason, i am Domenico
This is the main theory of Pier Luigi Ighina : "the law of rhythm"
http://fortunadrago.xoom.it/main/?page_id=279
I am available for questions on what are my knowledge of Pier Luigi Ighina and his theories
my email : derekwillstar@gmail.com
Bob Smith
It would be nice to pull together Ighina's work, theory and plans. His Elios claims to be able to neutralize radioactivity. There are many places where this would be useful.
The Elios looks fairly simple and straightforward providing you use the right wood, spring, paint and colour straws. Anyone able to share their experience with it and results?
Bob
