voltage amplification by flux exited self oscillating reed switch
Started by professor, September 13, 2008, 12:12:47 AM
nul-points
guten tag Professor
i'm a mere 'whippersnapper' (but hopefully not a 'besserwisser'!), 10 years your junior, so i'm not going to post my insignificant CV!  :)
if you have the time & inclination, i'd be interested to hear what difference the attached circuit (if the contacts still chatter) makes on your spark - and your relay switch contacts
(NB.  if HV develops across capacitor, don't continue without taking suitable circuit and personal safety precautions!)
PS - the following suggestion is just a 'shot in the dark' as to the effect of a particular magnetic pole on the reed switch contacts...
the magnet (N) approaches the reed contacts and they close, allowing current to flow through the wire and contacts
IIRC DC current passing through a wire will cause a kind of magnetic monopole, centred on the wire, polarised according to the direction of the current within the wire
i'm guessing that the direction of your current through the switch is such as to cause a South-polarised 'monopole' in the wire & switch contacts, as soon as current flows
the magnet is positioned such that the current-induced 'monopole' then cancels the effect of the field from the externally applied pole and the contacts open
when the contacts open, however, no current flows - so the external pole can now re-influence the reed contacts and they close again
...the cycle repeats
sounds like 'free energy' to me!  ;)
regards
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
mscoffman
@professor;
There is a good reason to try to suppress coil primary contact arcing;
My PMM rule of thumb is; "That anything consumed by a process must be considered a
fuel for the process." So if your device is consuming switch contact material it may be
oxidizing it or combining it with nitrogen chemically - you may therefore have an additional
chemical energy source. In a plasma with a magnet and you may have built a miniature
MHD magneto-hydro-dynamic generator.  So it may not be that suprising that you are
seeing additional energy. Too bad MHD generation has already been invented and if
the above conclusion is right then you don't have overunity energy. Just unusually fueled,
internal combustion.
web link wikipedia MHD;
http://en.wikipedia.org/wiki/MHD_generator
It reminds me of J.P. Newman's overunity unity patent motor where it kept consuming scotch
tape applied to the commutator. The scotch tape was being consumed by the commutator
and addition energy supplied to run the motor.
:S:MarkSCoffman
professor
Sandy
You are not a whippersnapper but you hit it right on.
One thing I might add that if I approach the switch with a Magnet  at 90 Degrees to its axis I can close  the switch as you normally would with a Coil around it or for the better it is then called a reed Relay. I do not know wether the switch is in a Vacuum or Gas filled, one would have to try to experiment using an open contact relay. Of course you have to switch it electronically while moving a magnet into the vicinity of the Contacts.Have not tried this yet
The magnetic flux does just what you explained so well and it does something else, which gives rise to the  Voltage Amplification .The flux  pulls  or pushes the spark over a large area of the switch contacts longitudinal,  those flashes are quite visible .
If the magnet approaches from 90 degrees there is only a tiny spark and the contact stays closed.
Thanks for the explanation
professor
Quote from: nul-points on September 14, 2008, 02:58:34 AM
guten tag Professor
regards
sandy
professor
Hallo mscoffman
I was not aiming to achieve any overunity nor to invent something new.
I simply did an experiment and reported it here.
Also you or I can not assume that the Glass envelope is filled with some sort of gas or Vacuum until we check the specs..
Professor
Quote from: mscoffman on September 15, 2008, 12:00:28 PM
@professor;
:S:MarkSCoffman
professor
Sandy
I just tried your circuit it does not work unless of course you reverse  diode D2 the one across the electrolytic . This diode is reverse biased blocking the current flow.Once reversed the Circuit behaves visually the same. I did not do any gain tests.
professor
guten tag Professor
regards
sandy
