Chem Trails The only buffer between us and the sun?
Started by blisteringanomaly, September 19, 2008, 06:38:42 PM
Michelinho
Hi all,
Chemtrails are real and they have caught on film a plane setup just for that purpose:
http://www.rense.com/general81/ddthr.htm
QuoteFig. 4 ­ Enlarged image of spraying pod mounted under port-side wing. Pod is painted to somewhat match the engine color on the plane. However, note pod mounting strut doesn't match the underside wing color. Note the number "2" on the pod. The starboard side wing is most likely pod #1. I have added the letters to identify key parts of the image which are referenced below.
Legend:
A - Propeller on the front of the pod drives an internal generator or pump. Based on the shadows under the plane, we can determine this image was made sometime around mid-day.
B - Funnel-cone with an exit port mounted on center of engine exhaust for additional spraying capability. Exhaust that exits here may not necessarily be superheated air, as most of today's engines are high-bypass designs for maximum thrust and efficiency. The engine could have been designed to have a fresh-air channel running straight down the center. This would be important when spraying biological agents in order not to destroy them.
C - Semi-circle black lines along the bottom are probably air intake screens. Being on the underside of the pod, they would be exposed to the high pressure flow of air under the wing.
D ­ Afterbirth: Curve of pod mounting strut almost matches that of the plane's wing, but is not quite perfect. No aircraft manufacturer would ever release a plane with the large gap in the mount that we see here. This pod was clearly manufactured by a third party.
Check it out for more info.
Take care all,
Michel
TechStuf
Great pic, Michelinho, and of course Chemtrails are real, anyone reasonably devoid of selective myopia can see the truth of it.  Googling the word: 'Chemtrails' brings up millions of pages pictures and video.
This is part of the reason for them:
http://www.telegraph.co.uk/news/worldnews/northamerica/usa/3222476/Suns-protective-bubble-is-shrinking.html
http://www.worldclimatereport.com/index.php/2005/05/10/global-warming-something-new-under-the-sun/
I seem to recall mention in the Holy Scriptures of Yahweh sending an Angel to do someting to the sun to increase the heat on the earth in the final part of the days.....
http://www.bible-knowledge.com/7-Bowl-Judgments.html
4th bowl
Blessings,
Mitch
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
