plasma plugs & HHO gen
Started by Eddio, September 24, 2008, 10:36:43 PM
Eddio
First off, I am new  on here and I don't know if this will even get through after so many trys :), but here goes. I am presently working on building my own or rather modifying a spark plug into a plasma plug and if this goes through, I will keep you posted on my progress. Also I have built me a reactor to produce HHO and on my first try with just DC current and after about one minute of operation after putting a match to my petcock it blowed out my safety plug with the sound of an m80, no problem as I expected that, My ultimate gold is to be able to break the water apart with ultrasonics, just as a specific freq will shatter glass, there must be a senitivity for various fluids and solids. I have had some experience with this field and some lab experience. As I progress I will gladly share my info.
professor
Hi
http://forum.healingdao.com/philosophy/message/12157%5C
You might be interested in reading that Article its been around for ages but you may not have read it.
I think you are on the right direction but it is an expensive one if you go via transducer.
professor
Quote from: Eddio on September 24, 2008, 10:36:43 PM
Eddio
There are various ultrasonic methods, some in the mechanical mode which produces a good bit of power, but uses compressed air.
One method is by a rotating disk, another is by an ultrasonic siren. Another method is by using harmonics to increase the intensity.
I know it is possible to emulsify as I was once a building inspector at Travis AFB and the contractors used an emuslified asphalt which
was called a slurry, As the water dried up the asphalt remained, but I am open for all suggestions
