Van de graff generator
Started by Dave45, September 25, 2008, 09:35:13 PM
Dave45
Has anyone tried a van de graff generator on a hho cell
HeairBear
I'm sure it has, do an extensive word search and you should find something. Here is a funny video of something similar.
http://www.youtube.com/watch?v=C2fUlcAzDWE
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
Paul-R
Quote from: Dave45 on September 25, 2008, 09:35:13 PM
These cells want low voltage, usually 2v per cell. This generator would
suit the antigravity lifter people who revel in appallingly high voltages.
professor
There is High Voltage and there is static Electricity which has a  High Voltage potential
Static electricity behaves different than conventional High Voltage.
Therefore I think author Dave45 has made a valid point,and unless someone has tried it, there is no need for an answer that does not relate directly to the question. Simply admit that you have not tried it and then submit your reasons and suggestions
Meyers quoted using high Voltage.  In comparison to a 2 Volt brute force cell anything above that can be construed as High Voltage.
Since we are not sure whether it is High Voltage low Current or for instance resonance that causes the Voltage to rise and the Current to drop similar as if you tune up an antenna we still don't know that  with the passing of a dozen of years .
Meyers can no longer be queried, but there is Dingle and http://peswiki.com/index.php/Directory:Water_Fueled_Car_-_Sri_Lanka
You may find your answers there if you can convince them to share it with you..
I have no van de graaf generator otherwise I would try it.Crazier things have been tried i.e. Cold electricity
professor
Quote from: Paul-R on September 26, 2008, 09:55:00 AM
Dave45
the reason I ask is Meyer's circuit was supposed to be high voltage low current, I thought a van generator would produce the effect but Im not sure if there's a way to control it.
Another thought if you take a plate capacitor made with donut shaped plates what kind of field would be produced inside the hole, and what effect it might have on water, Iv been collecting the disk's out of hard drives they have the right shape, Im thinking of making a plate capacitor and charging it with a van de graff to see what kind of field it would produce (electrostatic) but if the capacitor was hooked to AC current then it would be moving current (electromagnetic ?)
Iv got to get the generator first been looking on ebay sometimes it cost a chunk of change to check out an idea.
