Simple Device Which Uses Electrical Field Could Boost Gas Efficiency Up To 20%
Started by hazens1, September 26, 2008, 05:46:20 PM
hazens1
Saw this on Science Daily..
Want Better Mileage? Simple Device Which Uses Electrical Field Could Boost Gas Efficiency Up To 20%
http://www.sciencedaily.com/releases/2008/09/080925111836.htm
Bob Smith
Very interesting.  Sounds a lot like the magnet on the fuel line strategy for extra mpg.  Wondering if this same effect could be brought about using a battery running to a coil around the line to an led and back to battery (1.5 or 9V?).
B
professor
Hi Bob Smith
I believe you can, but it comes at the cost of Power and in order to produce as much Magnetism as some of the Neodemnium Magnets produce it is not economical to go that route.
There is a Device that years ago was imported from Austria and may still be sold in Canada, it used no power and clamped onto your water supply line realigning the calcium particles (not removing them) that they would no longer stick.
Have not tried this but I heard that it works and so does the same or similar device for your Gas supply line.
professor
Quote from: Bob Smith on September 26, 2008, 06:05:15 PM
B
professor
Sounds good but the device  looks like  Backyard Construction  unless they are displaying a Prototype.
Does not look instilling to me right now.
proessor
Quote from: hazens1 on September 26, 2008, 05:46:20 PM
hazens1
More info...
In the device, the fuel flows through two metallic meshes before it reaches the fuel injector. A voltage is applied on the two meshes to produce an electric field of about 1 kV/mm between the two meshes.
Electrorheology Leads to Efficient Combustion
http://pubs.acs.org/cgi-bin/sample.cgi/enfuem/asap/html/ef8004898.html
