EL IEVE free energy magnetic mill
Started by CLaNZeR, September 27, 2008, 01:37:40 PM
Agustin
Quote from: Thaelin on October 28, 2008, 03:05:57 PM
   Many thanks to Agustin for the video of the material he used. It brings forth
an idea or two. Would bet tho that that specific material is "proprietary" and
therefore not available.
thaelin
Excuse Thaelin: P does not understand what you said, because my translation is half bad jejeje.
Thaelin
   The slow video is the transfer rate. If you notice, it is buffering a lot of the time when it
freezes. As for the boxes, just watched the vid. Still interesting stuff. and to think of all
I have thrown out with the old drives.
   I would like to get it in a pre-defined form so I could play.
thaelin
Agustin
Ha con respecto a lo anterior, me alegra haberte dado ideas :D. Respecto al video si queres te lo envio por msn. Espero haberles sido de ayuda, y cualquier pregunta o duda respecto a lo que hice, me consultan :D.
Despues voy a subir mas cosas y los mantengo al tanto.
Saludos Agustin.-
PD: Si de casualidad consiguen "ferrofluido" o "fluido ferromagnetico"; me avisan, asi les consulto experimentos para hacer usando el magnetic shiel y el iman. Que obiamente ayudaran al desarrollo del mismo.
______________________________________________________________________________________________________________________
Has with regard to the foregoing, I am happy to have given ideas: D. Regarding the video if you want it sent by messenger. I hope that I have been of help, and any question or doubt about what I did, I consulted: D.
Then I'm going to climb over things and keep abreast.
Greetings Agustin .-
PS: If you get the chance "ferrofluid" or "ferromagnetic fluid", warn me, so I consult them for experiments using "magnetic Shield" and the "magnet". To assist the development of it.
nievesoliveras
Hi!
@thaelin
Thank you.
@agustin
Yo creo que lo que thaelin quiere decir es que el material del que esta hecho el shield del hardisk es bien dificil de conseguir, debido tal vez a que lo manufactura una compania en especifico. Aunque tambien puedo estar equivocado.
Jesus
Agustin
Hi Jesus:
No sabias que hablabas español. Mejor :D. Ha y gracias por traducirme mejor. Mira si es verdad es muy dificil de conseguir, pero hay empresas que lo venden. El problema es que es muy caro, asique tendriamos que experimentar con los "magnetic shield" del harddisk moldeandolo a golpes y cortandolo, como lo hace los herreros pero sin calentarlo.
Pero para dar tanto esfuerzo se tiene que justificar!. Por eso, es que quiero conseguir el "ferrofluido" o "fluido ferromagnetico".
Despues subo un flash para que vean lo que quiero decir.
Y en mas elegi el motor de "molino magnetico" de carlos aviles porque solo habira que moldear los magetic shield para semi-tapar los imanes de la helice.
Una vez mas gracias jesus por la traduccion.
Saludos Agustin.-
Hi Jesus:
Do not know you were talking Spanish. Best: D. And thank for translated better. See if it is true it is very difficult to achieve, but there are companies that sell it. The problem is that it is very expensive, So we should experiment with the "magnetic shield" of the harddisk die-casting coups and cutting, as blacksmiths but without heat.
But to give so much effort has to justify!. So it is that I want to get the "ferrofluid" or "ferromagnetic fluid."
Then upload a flash to see what I mean.
And most elected engine "magnetic mill" by Carlos Avila because only habira that shape the magetic shield for semi-cap magnets of the propeller.
Once again thank Jesus for the translation.
