Stanley Meyers Injector Revealed
Started by sirmikey1, September 28, 2008, 10:30:15 AM
sirmikey1
This was posted on energeticforum
Water Atomization by High Magnitude Electrical Impulses: A study.
http://www.powerlabs.org/waterarc.htm
professor
Hi sirmikey1
I hate to say this again,but after looking and reading your link Material at www.powerlabs.org/waterarc.htm, I find that this article only confirms my previous statements. And for clearer understanding I shall quote
Statement:     An SCR Handling 3000Vdc High current (maybe?)
Answer from Quote:
The discharges were switched by a homebuilt pneumatically actuated switch, consisting of two 10cm diameter spherical electrodes, one stationary and the other propelled by a 450Newtons piston. Switch closing time is
calculated to be 80uS at 7.5kV).
Statement: Try the same in rapid succession at 2000RPM Plus.
Answer:  10 discharges were run in 20 seconds
Statement: The cost and size of your Capacitors and High Voltage power supply that must rapidly replenish the spent energy is just not practical
Answer: 562500Watts 36uF MAXWELL capacitor charged to 7500V
Though the capacitor is rated for a peak amperage of 60Kiloamperes, during the 3rd discharge it suffered internal damage, evidenced by excessive bulging to the case. A careful autopsy of the dielectric revealed no punch throughs: It appears as though the discharge exceeded the maximum amperage of the capacitor by so much
Practical Useage?
After several discharges the pressure inside the box remained at 1ATM. If the water was being vaporized by the discharge a phase change expansion would be expected and hence some pressure increase should be observed. Similarly, if the water was being split up into hydrogen and oxygen by electrolysis, an even higher pressure increase should be observed. More importantly, there was no "fogging" inside the box, further refuting any steam condensation claims, and the temperature change was consistent with my theory that the water is not being vaporized. If only a small amount of Hydrogen and Oxygen was being produced,
Quote from Article:
The zero pressure increase tells us that this change is non permanent and very quick. We can therefore rule out vaporization, and electrolysis, as both would result in a permanent pressure change.
Meyers contemplated using additional Laser Energy He was not using it on his Dune Buggy Injectors should I be wrong then please show me where it says that he did.
Again for certain Lasers as they are pulsed you require a precision high Voltage
Power supply and the cost vs. Gain is questionable.
I don't think you can achieve any kind of reaction by using 5to20 mw Laser diodes
Beyond that you are looking at thousands of dollars even for a CO2 Laser,
which is bulky anyway. You will never fit any of that kind of laser into your water spark plug.
Anyway ,Good luck , I like to see you succeeding and to prove me being wrong.
professor
Quote from: sirmikey1 on September 28, 2008, 05:30:55 PM
Professor:
  Meyers also added Lazer energy.  Would
this satisfy the operation and economics"?
Meyers exact words (Switzerland Video):
This all happened by "Presidential executive action!"
SM
sirmikey1
Professor,
  From what I understand, the Lazer is applied to the charged water first,
so that very little electricity is required to cause the explosion/split.
I just had an engineer who has read the patents confirm this. I also
just asked Tom to put something together for us on youtube, to get
rid of the capacitor bank.   Tom has a complete workshop.  He built
the rotary engine himself.
SM
professor
That's interesting ! always eager to learn something new.
Don't read me wrong I am a believer in this and other technology but I also know of its shortcomings or law of improbability when it comes to Electronics.
Do you have a copy or the Link to Meyers Patent paper regarding the Laser?
I know that you can split water using a specific wavelength in the UV region just how effective it is ,remains to be seen .It should be fairly simple to do a test setup and I am wondering why no one has tried it yet.(Maybe due to its cost)?
Getting rid of the capacitor Bank and still have lots of amps on demand at short intervals with high voltage ought to be quite a challenge.Keep me informed when you have  figured it out. I myself would not know how else this can be done. Radar, lasers, even high power Audio Equipment all  rely on  exotic Capacitors for high demand.
professor
Quote from: sirmikey1 on September 28, 2008, 09:33:55 PM
Professor,
SM
sirmikey1
Professor,
Around 40 patents, and I don't exactly know which one,
but I did contact Matt to see if he recalls.
  The torrent here also has the xogen documents, which took
over after he supposedly died. His European patents are also here,
http://isohunt.com/torrents/?ihq=free+energy+meyer
SM
