Atmospheric powerplant
Started by Aleksey, October 04, 2008, 10:06:36 PM
jadaro2600
Yea, lets put more hot air into the upper atmosphere.
hammuraby
yes, this is possible.....
but whit a menagement of surface water, that reach the water uphill ,
no problem for athmosferic danger;
and a air compressed for stop the true tornado...
the power of device is 1,5 mega W
christo4_99
i only wanted to post here to relate one concept:the release of co2 into the atmosphere causes warming in that the atmospheric gases are just that,gases and the c in the co2 is a solid,solids retain heat.that is the problem.the bonded carbon is a heat retainer.co2 is 33% solid and 66% gas,not by weight but by form.it is the 33% solid that is the problem.
as far as your idea:look into actual wind current and how they swirl northward and southward at the eqautor...this is the place for you...if you made it big enough it would work.
hammuraby
what made a solid state, end gas, is ONLY the atomic density, becausa a atomic heavyness of H is 1, oxigen is 8, and C is 8 (same)
that naturally at 1 ATM is diffrent the state of density between C and CO2....
the CO2 is  more heavy and more mass then other gas, but NOT too much...
YOUR is a OLD thinking , because a KIOTO protocoll will be turn (2012) in Chopenaghen Protocoll
is then usefull take avay a C from the athmosfhere using a bio-charb, that is formed from phirolisy of wood... a 1 Kg of charbon (2 Lt ?) is the same of 3 Kg of CO2, (1,63 Kg a Mt3) that means 2000Lt of Co2 in a 2Lt of BIO-charb = as a 1000 BAR undergraund boundage
this is a OLD doingness usefull only for a FINANCIAL feed-back of OIL company
triffid
You guys are forgetting about methane gas(which absorbs 20 time the heat that CO2 does).By the way a gas is a solid that is in its gasous phase.Just take away enough heat and all of these gases become solids.CO2 and methane will freeze solid when temps drop enough.Triffid
